Starlet__SR Posted March 8, 2009 Posted March 8, 2009 What exhausts can you get for a N/A Starlet? I have an Sr and am looking at buying an aftermarket system. Does a glanza system fit from the cat back???Any info would be greatly appreciated.Many thanksDamien Quote
Craig_N Posted March 8, 2009 Posted March 8, 2009 The best system for the n/a is prob the one ROBSR is selling in the for sale section and it is very cheap to.Craig Quote
ste91 Posted March 8, 2009 Posted March 8, 2009 The hangers etc... are the same but the actual bit where the exhaust connects up to the downpipe/manifold are obviously going to be different because of the turbo. Could do a custom job on it though. IIRC the standard Glanza system is 2 inch diameter? That would be ok for the N/A but anything bigger is too much IMO unless the engine is heavily modded.Don't take my word for it though, best to ask someone who has actually had a different exhaust fitted. Quote
Starlet__SR Posted March 8, 2009 Author Posted March 8, 2009 The hangers etc... are the same but the actual bit where the exhaust connects up to the downpipe/manifold are obviously going to be different because of the turbo. Could do a custom job on it though. IIRC the standard Glanza system is 2 inch diameter? That would be ok for the N/A but anything bigger is too much IMO unless the engine is heavily modded.Don't take my word for it though, best to ask someone who has actually had a different exhaust fitted.So what about from the cat back???? Can't see no real difference as its the same floor plan, and in all honesty, I only want the mid section as I want to keep my tte backbox. Engine is standard bar an air filter, just want a bit more noise without being stupid or losing originality.Thanks Quote
BAZ2CRAZY Posted March 8, 2009 Posted March 8, 2009 Not much point then surely?Not yet a manifold designed for the 4e, so you would have to keep that standard, theres a cat and midbox on the centre pipe so unless you want to decat theres not much point in looking for a mid section. I have a glanza s zaust which is decated with a stainless centre pipe.Could do that?go to a zaust fabricator to have a custom centre pipe made.If i were you id keep the tte box, if you change it, il buy it Mitch Quote
Bluebear Posted March 8, 2009 Posted March 8, 2009 About the mani, there is a 4EFE mani group buy going on, whch will be fabricated by Starbus! Quote
Starlet__SR Posted March 9, 2009 Author Posted March 9, 2009 Well basically i'd like a straight through pipe from the manifold to the backbox, the silence is killing me, and I don't fancy having something fabricated as it isn't tried or tested, it's just made to fit, not to suit the engine or car. As for the manifold, I found this?It's for the 5EFE, but been told there's a possibility it may fit, but i'm unsure, anyone care to shed some light???5EFE Manifold Quote
Starlet__SR Posted March 9, 2009 Author Posted March 9, 2009 Not much point then surely?Not yet a manifold designed for the 4e, so you would have to keep that standard, theres a cat and midbox on the centre pipe so unless you want to decat theres not much point in looking for a mid section. I have a glanza s zaust which is decated with a stainless centre pipe.Could do that?go to a zaust fabricator to have a custom centre pipe made.If i were you id keep the tte box, if you change it, il buy it MitchThe manifold i'm not too bothered about, but between that and the backbox, i'd like it straight through, with the option to bolt a cat in for mot purposes, and as for the tte box, I might sell it, depending on the price. It's nearly new, only a couple of months old, sounds nice from outside. Quote
5T4R7ET N/A Posted March 9, 2009 Posted March 9, 2009 Best option for performance wud be a custom 2inch diameter pipe, with small middle box and back box. And u can have a removable cat.Or have a cat, no middle box and a back box.As for 5EFE Manifold there has been loads of discussion of it in the tech section Quote
Starlet__SR Posted March 9, 2009 Author Posted March 9, 2009 Best option for performance wud be a custom 2inch diameter pipe, with small middle box and back box. And u can have a removable cat.Or have a cat, no middle box and a back box.As for 5EFE Manifold there has been loads of discussion of it in the tech sectionNot after performance as such, justr aesthetics, plus the mid box catches quite easily, will end up ripping it off. Quote
BAZ2CRAZY Posted March 9, 2009 Posted March 9, 2009 The manifold i'm not too bothered about, but between that and the backbox, i'd like it straight through, with the option to bolt a cat in for mot purposes, and as for the tte box, I might sell it, depending on the price. It's nearly new, only a couple of months old, sounds nice from outside.PM me if you do plan on selling itMitch Quote
G-MonSteR Posted March 22, 2009 Posted March 22, 2009 hey! has anyone got the link to the 4efe mani group buy? because i can't seem to find it Quote
ste91 Posted March 22, 2009 Posted March 22, 2009 Here it is http://www.ukstarletclub.com/forums/index....showtopic=17369 Quote
