Starlet SR Posted July 19, 2009 Posted July 19, 2009 is it possible to fit a 4efte inlet mani fold and 4efte bigger throttle body to a 4efe ?we all know that the rolla manis are a great mod for the n/a but surely you would get more performance out of a bigger throttle body of the fte jus wondering if any one has done this cheers folks Luke Quote
Jozinobi Posted July 20, 2009 Posted July 20, 2009 The 4EFTE inlet mani will fit with some modifications such as the blocking of un needed vaccum lines, removal of the vacuum log that comes with it and a few other things (angle grinding of throttle cable holding area). The 4EFTE throttlebody will not fit because it has completely different sensors. Joz Quote
ste91 Posted July 20, 2009 Posted July 20, 2009 As far as I know the 7AFE throttle body will fit. Not completely sure though. Quote
STEVO9000 Posted July 20, 2009 Posted July 20, 2009 As far as I know the 7AFE throttle body will fit. Not completely sure though.Thats rightI've got a 4efte/5efhe inlet mani on my Paseo with a 7afe 50mm TB Quote
Asad Posted July 26, 2009 Posted July 26, 2009 Yup, just checked it out only problem you will have is the powersteering rack vac pipes theres no "holes" for them everything else checks out 7AFE Tb avaliable from the avensis + carina E2 coolant pipes on the bottom3 wires for the TPS (black,blue,red)3 wires for the ICV (brown, black, black+yellow)1 vac pipe on top55mm (internal dia)Just read......http://www.ukstarletclub.com/forums/index.php?showtopic=9703&hl=7AFEno point on a corolla mani really, would be better with the FE and FTE. Quote
Asad Posted July 28, 2009 Posted July 28, 2009 Yup, will you be fitting it to a corolla mani or the standard one? Quote
rmsnoel Posted July 28, 2009 Posted July 28, 2009 The fte manifolds sounds much better than the noisey corolla manifold. Really heavy grunt out of it. The 4afe throttle body would be a better option from the 1.6 engine. TPS sensor fits all good and well. the throttlebody will have a gap below it at the manifold so you need a wee plate made up to block this gap. You'll see wat I mean. Also take the throttlebody studs and bolts from the 4afe manifold cause they are longer. Now you can add or reduce spacers to increase your torque with the fte manifold Quote
STEVO9000 Posted July 28, 2009 Posted July 28, 2009 You just block off one of the vacuum lines, thats what I've got done on my 5e Quote
