Thought id get this up here, Decided last week to get my old matt black starlet back on the road now my other one is sold. It was a fully forged, TD04, with piggyback ecu.
here it is at the moment
Then i removed the engine and box
And thats about as far as i have got for the moment.
As you can see its been sat there a while, 2 years i think But I've now sold my HRF TD05 starlet so its time to give it some attention.
Got everything out of the engine bay ready for a clean up :(
Removed the dash to rewire the ECU for standalone, rewirer the ebc, gauges and rewire the lambda back in.
Managed to get hold of a Standard box with a 1.5way TRD diff and driveshafts :p
Gave it a bit of a clean up
The clutch was pretty worn, rivets are pretty much flush with the pads
Block stripped down ready for a clean and paint
Now painted in Heat resistant Tank HR paint :p
and before anyone sais anything i wasnt the one that cleaned the pistons up.
My ross pistons :p
My Pauter Rods
Everything cleaned up and painted
Matt black sump
The parts have started to arrive, Got some of the gaskets, magnetic plug, dizzy, wheel spacers and extended wheel nuts
  • Replies 65
  • Created
  • Last Reply
Top Posters In This Topic
Luke: will do mate Got hold of the rad from japan only took 2 days to get here and cost £200
Decided to get the boring bit out of the way, cleaned it up then sprayed it matt black to match the rest of the car :thumbsup:
Few more bits
Lightweight pully
Panard Rod
Adjustable Rear ARB
24mm Front ARB
Cusco Lower Arm Bar
Adjustable front strust brace
Front and Rear Braided lines
K-SPORT 6Pot calipers :rockon:
Pretty thick huh???? Should be more trhan enough
badassracer69: Thanks buddy will do.
mickyboy: Yeah I've always wanted one mate, Never actually used one before bit i know there pretty awesome.
Sparky: To cut a long story short i got this PFC off my other starlet that i brought from japan :( Just had to get a Commander and they ended up sending the wrong one so now i have two :)
Haha do it mate you can never spend enough, Getting seriously pissed off with it atm been flat out on it when im not working putting some serious hours in, took an hour to do the valve stem seals they were that bad cheers for getting them over so soon rik, Took me 6 hours to rub the valves in, No1 had a leak it was that poor :) , 3 hours to fit the cam gears on the inlet side as it wasnt machined properly. The cam gear had not been tensioned and have just measured the shim gaps 2 out of 16 are ok :lol:
i need tools first. my mate who loaned me his took them all back lol. weathers gettin to crap to work on it anyway. saying that , the weather was never really good :lol:.
Got my ARP Headbolts now, Thanks to dave for getting them here so fast :ph34r:
Russleh: Just get on and do it the weather is going to get alot worse than this, otherwise you will be waiting for next summer.
Boostjunkie: Thanks, I got them somewhere off :lol::D Ebay :):ph34r: If you want to know where send me a pm and i will send you a link.
