I am wanting to put 195/50 tyres all round, though my car is lowered 40mm and i think it may scrub on the arch, will i need a panhard rod or some thing else to be able to put 50s on, or will i need the arch rolling. If any one can help or there is some thing else i could get Thanks.
Actually i might be talking bollocks, i cant remeber why i think there height adjustable, either way 40mm springs on koin's sit way lower the 40mm springs on standard shocks
wheel offset mate, that what counts.
WIKI speaks:
Zero Offset - The plane of the hub mounting surface is even with the centerline of the wheel.
Positive Offset - The plane of the hub mounting surface is shifted from the centerline toward the front or outside of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative Offset - The plane of the hub mounting surface is toward the back or brake side of the wheel's centerline.
"Deep dish" wheels typically have negative offset or a very low positive offset.
To maintain handling characteristics and avoid undue loads on bushings and ball joints, the car manufacturer's original offset should be maintained when choosing new wheels unless there are overriding clearance issues.
Wheels are usually stamped with their offset using the German prefix "ET", meaning "Einpresstiefe" or, literally, "insertion depth". An example would be "ET45" for a 45mm offset.
