Hey,
Ive seen alot people pressure washing the engine.. !
Wont this ruin your engine?. if not then what products do they use to clean all the S#it off ?
Cheers
Adam
well i do it on about 10cars a day at work never had a problem. only ever had one problem and it was on my own car and just got some water in the spark plugs.
took out the plug but them back in and it was fine but that was one in proberbly 20 or more cars
yea as stated as long as you dont get to carried away with the power washer/hose any automotive all purpose cleaner or engine degreaser like gunk will be fine!!
cover the essential parts up with kitchen foil (dizzy cap etc etc)
spray degreaser everywhere
let it sit
work it in with a hard bristle bursh
let it sit
wash off with a low pressure hose
hand dry what you can
peel off the foil
wait about 5min
start car
How i do mine with no problems at all :thumbsup:
Im gonna give it a go at the weekend! what product do u recomend?
Yes, me too.. Ive heard everyone say use GUNK so ill give that ago!
can get autoglym from halfords which is good. as already said spray it everywhere and use a stiffish brush to work it in and just use a light spray of water to rinse it.
  • 4 months later...
let it sit
let it sit
peel off the foil
wait about 5min
start car
How i do mine with no problems at all :)
sound like what i did to mine,
i used an engine bay degreaser from homebase it was £5.99 and probably the best 6 quid i have spent on my car,
it says on the side of the can what you can't spray, and if you think anything else should not be sprayed cover it then go nuts, just make sure to remove the battery when you do it!!!!!!
and for aplication a household paintbrush is perfect but something cheap about a1inch or even half inch is great if you have the patience
before cleaning
after degreaser
after detailing (leads cleaned with white spirit, head and airbox sprayed)
hope this helps
  • 2 weeks later...
Degreaser works wonders, don't bother buying expensive products, my engine bay was cleaned with a couple of bottles of cheapo 99p degreaser, just spray it on (standard EP91 N/A engine so didn't really need to cover anything up), then just keep spraying more on and the dirt will just fall away.
Then get the hose pipe on a very fine mist and rinse it off, it comes up really clean and that's without any effort! Just spraying the degreaser on then rinsing it off, and it barely cost anything!
Once that's done start the engine and let all the water evaporate off.
traffic film remover and just a hose pipe and a brush from the dust pan lol, i got juddering as a wet the dizzy lol watch out, tfr works really well, if not tar and glue remove then polish it loads makes it easyier next time you clean
