The Quiet Acheiver N/a Ep-91
hi
been a member for a while now but forgot to post my ride willgive you the whole history up to current
some of the members here have contributed
1st photo`s of my car
CURRENT MODS
Kings Spring/KYB shockies
Rr Stabiliser bar
Window tint
wheels 15x6 tyres Sumitomo 195-50r15
everything else std
FUTURE UP-GRADE on the shelf
disc brake rr end
side skirts /spoiler
white dial cluster
2" stainless exhaust &extractors
microtech ECU
clear lenses
glanza rear t/lamps
led bulb set
hid h/lamp kit
will update photos as transformation happens
XMAS2009 UPDATE
finally fitted rear disc brakes
painted &fitted electric folding mirrors ( issue with wiring loom in car need 2 wires for fold function)
fitted corolla mani/T/B combo retuned (see other post for details )
finally got my tacho working
last of the LED bulbs fitted
fitted cupholder &armrest
started to sort parts for twin -pot frt brake conversion (couldn`t make UK guide work with au parts so will write guide when i get to fit up my brakes calipers fit straight on but getting a disc is proving a worry but i am very close )
keep watch for update
waiting for hose &vac pipe kit to arrive
will post more photo`s etc
sorry for quality of dash photo will replace with a better one later
corolla manifold &T/B fitted
rear disc`s fitted
NEXT trip /update to town UPDATE XMAS 2010
frt disc twin pot conversion now fitted &road tested big improvement in braking
some blue silicon hoses now fitted
camshafts /valve springs / thin h/gasket PNP head all fitted
ITB`s fitted tuning on tuesday
hope you like my build
lyle
Some nice work so far man :blink:
Did you have much trouble with wiring the Glanza dials?
Joz
hi
did the wiring the hard way ,pulled all the wires out of the plug &repinned the plugs withh the help of wiring digrams &tester there is probably a simple way
lyle
how did u do the rear discs? did u just find a rear axle off a v? and how much did it cost u?
wanna do mine but not entirely sure how to do it
hi
got hold of a glsnza axle (non ABS) from my local import wrecker &he supplied everything less axle posted to me to save weight it all bolts up to a std axle . you need the handbrake cables as well cost $400
lyle
WOW back end looks pretty much what mine looked like! Is it a carbon spoiler?
I like the exhaust manifold what one is it?
This is the best colour n/a wthout a doubt :blink:
hi
WOW back end looks pretty much what mine looked like! Is it a carbon spoiler? it`s not a carbon fibre, i left it the original colour , it`s a deep black with a silver sparkle in it , it seems to match the blue well.
I like the exhaust manifold what one is it? they are "pacemaker" extractors . you`ve probably heard of them. they are flanged to a 2in stainless exhaust shop built system
lyle
^^^ about that extractor. Where can you buy them from
Have you thought of getting matching black glanza side skirts?? Wud complete the look!
hi
about that extractor. Where can you buy them from go to http://www.pacemaker.com.au/index.html & select a dealer they are readily availiable in australia.
Have you thought of getting matching black glanza side skirts?? Wud complete the look! have already fitted colour -matched skirts trimmed with black chip-proof paint underneath skirt , used to paint rocker panel black in the old days , trend seems to have moved on &you don`t see too much black on rocker panels
lyle
  • 10 months later...
  • 5 months later...
hi all
latest photos of last updates
fitted ITB`s &finally got them working
fitted vac manifold & silicone hoses
painted wheels
fitted BMC air filter & plenum ( big improvement from sml cone filters fitted when i bought originally )
fitted head / thin gasket & camshafts
any videos of the ITB's?
hi
sadly i don`t have any videos but you could only hear the ITB`s with the cone filters.
after fitting the plenum &air filter the induction noise is gone .
it just revs more freely & doesn`t gasp for air. the cone filters seemed to choke the air supply even though it ran ok
photo from previous owner as i bought them
lyle
looking mint dude! glad the bmc filter got there in one piece! :) looks mint! top work bud
get a vid of the itbs running :)
hi
i guess i`m not into vid`s the way you guy`s are but there is hardly any induction noise with the filter fitted just free-reving power
the cone filters were noiser
want to see what my adj HP figure is after fitting BMC
lyle
hi
lyle
What power you makeing on your set up lyle?
hi
to all the N/A fans
this is the the history of my up-grade in dyno-graphs
std no mods = 35.79kwatw 48kwatw
1st mod is exhaust/ ECU =54.4kwatw 74HP
2nd mod is corolla mani & T/B =59.5kwatw 80.9HP
3rd mod fitted ITB`s with&without cone filters fitted =65.77kwatw 88.2HP
4th mod fitted plenum& BMC filter & re-tuned =68.01kwatw 91.2HP
don`t know what else swap this will probably be it for a while
hope you like the up-date
lyle
