  • Replies 676
  • Created
  • Last Reply
Top Posters In This Topic
If stupidly tight then yea, just back it off a touch then :)
Should there not be a hole in the shaft for a split pin aswell? Give it a tighten up with a power bar and if there is a hole line it up and fit a split pin bud!
ro55ifumi has wrapped his ramhorn mani really nicely, have a look at how he did it :)
I think if you wrap it all uniformly leaving no gaps, it should be okay, even if the spaces between the runners are different
Thank you and as already stated wrap in pairs :p start from the turbo flange end an finish at block end
Soak the wrap in water before applying an wear gloves :(
John
ive been doing it up tight but then it keeps coming loose an it does have a split pin also , its whats confusin me lol !
i used gloves last time n it still made me itchy haha, ill have to do it on sunday now , ill need some more stainess ties too , and im hoping ive got enough wrap , it will be ok to take off wet and do it again dya think?
i dint wet wrap last time does it matter? cause if it does ill have to re-do decat too
Wet allows it to stretch and bed in when warmed up drys off and sets :), if you look i only zip tied one end, the other is wrapped around on its self :(
well ive now odered some more SS ties and some oil and coolant
i went for the Millers Oils XSS 10-40w for the engine oil and fuchs ESKIMO for the coolant :rolleyes:
now lastly i need a bend for the airfilter 55mm for td04 to the airfilter which im not sure on the size lol
nothing too intresting just been a busy day
i had a call to pick up my welded turbo - excited much yes!! lol
so then on arrival at home i saw a big box with an envelope on top
the box contained these two lovely items
and then in the envelope came SS so i can re do my dodgy wrap attempt ( will be done sunday )
also some spare for the 30m of wrap for the exhaust lol
also got given this, which i hope will suffice as an oil feed return
and then i decided to go poundland , to buy more gloves for heatwrap and some sponge rollers so i could finish painting the boot
1st layer
2nd layer ;) thanks to the missus
depends on how this drys i may do a third layer
and lastly i am now complete so 100% ready to fit my td04 and £3000 worth of goodys lol
i am currently on the lookout for plug n play 460ish cc injectors
thanks for reading the essay lol
Nearly there then.....
haha yeah , hopefully fit it all without a hitch drive round til august and then get a mapping ecu
probs guna go to dave@tmd for a dastek uni chip Q
i literally just need injectors , fuel pump, then mapping
although plug n play comeing up cheap lately like £350-£400
PM me about the ECu if your interested, to be honest its the last part of my starlet left need it gone ;)
My 460's will be for sale, away for the weekend so PM you when I am back
i hope ya not breaking ya whole car ! lol
PM me about the ECu if your interested, to be honest its the last part of my starlet left need it gone :thumbsup:
yeah will do bud , just guna sort out and find out some info on em and td04 etc
right so after messing up my first attempt at heat wrap i redid it using a bucket of water and alot of patience
piece of advice to people - dont bother wrapping lol ITS FREAKING HARD
anyway looky look
and
im contemplating going for a plug n play as a couple have come up cheap and i cant afford a map and ecu til end of august so this will tie me over til i can afford to buy a better ecu injectors etc
whats peoples opinions? IAMLEGEND loves his
also best news yet
IM STARTING THE PROJECT THIS FRIDAY NIGHY AND HOPING TO END SUNDAY SO PEOPLE BEWARE OF THE HELP THREADS LOL
:thumbsup:
right so tonight i started the car ;) excited much - YES!!
well got the car up on all 4 axle stands , and started to strip the radiator , manifold, turbo , down pipe , all gaskets , water oil lines , all the neccasary parts and now just left with what i need to fit
so 2moz (friday night) hopefully get the manifold on and the turbo etc all bolted up , sandwhich plate sensors and gauges fitted
then saturday wrap the exhaust bolt everything up properly get all the wiring connected and set up , find a place for the gauges and controller , strip old gauges etc then hopefully be finished and connect it all up fit the rad and put the fluid and engine oil in then start her up
or if not sunday will be the test day ;)
only got a couple of crap pics
boxes full of awesomeness
how the car started
and how it finished after 2 hours later
and the car now flying ;) with powaaahh
haha long time its only taking me 7 months to get all the parts together lol !
cheers guys and sparky you know your guna keep it and get it mapped ;) so shhh lol
plus ive brought a bargain of an ecu
got a emanage blue , with ignition harness, injector harness and field harness for the 82 so literally plug and play and away i go for a mapping plus a walbro 255lph pump delivered including fess of £310 <-------- bargain ?
it aint :'( lol
i just need 5 o clock to hurry up so i can do some more on the car then 2moz on the car then sunday it either blows up , cluctch goes i crash or ......
i use a shit load of money on fuel lol
whey ! youve got to really i was planning on 1.4 bar boost now ima stick with 1.2 also lol but like people say its still guna be rapido!
right so again 2night went to my mates to start on the car ,
first of all removed the FMIC just to give us more space
then we angle grinded the bottom rad brackets off to fit the new civic rad
then we decided to fit the sandwich plate (which would later kill the night)
so we started to grind away at the PAS bracket, eventually got it grinded down enough
, measure up with the plate all fitted fine n dandy , then dipped the rubber ring in old oil to make a seal and what happens .....? now the rubber has made it like 3mm to thick so the 3/4unf now doesnt fit !! like seriously WTF !!
so basically tonight was wasted on trying to get the sandwich plate to fit
now tomorow means going to buy a new one :) whats a waste of a night and money
so now car aint guna be done by tomoz and ill be lucky if its done by sunday
oh and also decided to sort out the horrible tacky yellow , primer all over my front bumper,so shud make the car look ok in pics lol
