Okay lads (and ofcourse, ladies)
Lets have a thread where we can compile some fantastic things the EP has brought us over the years.
Personally trying to compile a knowledge in everything EP so I'm looking at Phil here... but i'd love to see pics, specs and random details on some of the finest legendary EP's going.
For what this is, its totally secret for a while, all will be clear soon :thumbsup:
Sam
  • Replies 131
  • Created
  • Last Reply
Top Posters In This Topic
Il kick this off.......
JAM RACING WORKSCARS - 4e spec
Was for sale in the homeland for 2,700,000 Yen in price
At 1999 Tsukuba circuit marking 1 minute 4 seconds 867
Engine itself
4E−FTE base
Forging piston original lightweight [baruburihuta] piston and connecting rod balance taking
Deviation prevention process blow-by gas prevention processing inside oil pan
Turbine air cooled conversion processing
Trust 10 step oil cooler kit
JAM original preface [intakurakitsuto]
Blow off valve less
NGK plug cord
NGK racing 8th plug
The control with JAM original CPU
Turbine
Genuine reforming high flow
Strengthening actuator
[torasutopurohuetsuku] B specifications installation
Exhaust type
JAM original catalyst extension
JAM original TYPE2 muffler
Drive system
Mission itself normal
Only final 4.058
AP racing twin plate clutch
TRD mechanical cable type 1.5WAY LSD
Brake
Front carry per Will Wood 4POT carry per
4POT private brake pad
Rear JAM original type RC brake pad
AP racing adjustment type proportioning valve
APP stain mesh brake line
Suspension bushes
Front
The Cuzco camber adjustment type pyro upper mount
Height pitch for TRD race/lace
Series-wound coming spring 14K for TRD race/lace
Rear
TRD strengthening upper mount
Series-wound coming spring 12K for TRD race/lace
TRD suspension bush
TRD strengthening engine mount
JAM original pyro lateral rod
Interior
[buritsudojigu] you [hurubatsuketoshito]
3 inch [uiranzu] 4Ã?4 seat belts
[kusukokuromoriroruba] 7 point system
Trust 60φ boost gage oil temperature gauge
The ultimate ep imo.
Cruise Demo Car.
Specs are as follows:
Rebuilt Forged 5e Engine by Cruise
Cruise Power 74.5mm Pistons
Cruise Power Forged Conrods
Cruise Valve Springs
Cruise Power 1.2mm Head Gasket
Cruise Power 550cc Injectors
HKS F-Con Gold Pro V Standalone ECU
Uprated Fuel Pump with Swirlpot
Cruise Power 264/264 Cams
Cruise Power TD04H Turbo
Cruise Power Exhaust Manifold
Cruise Custom Downpipe
Cruise Adjustable Cam Pulley
Polished/Ported Head
Blitz 210 Fuel Pump with Cruise Pump Relay Kit
BLITZ Front Mount intercooler
Trust Profec B Boost Controller
Trust Oil Cooler Kit
Fujitsubo Power Getter
Front Roll Center Adjusters
Cusco Lateral Rod
TRD Engine Mounts
TRD Lower Arm Bush
ATS 1.5way LSD
Cruise Clutch, Cover and Lightweight Flywheel
Bilstein Coilovers with Swift Springs (12kg front, 10kg rear)
TRD Adjustable Top Mounts
AP Racing Big Brake Conversion
Endless MA45B Pads Allround
WEDS TC-005 Alloys (225/45/16 front, 195/50/15 rear)
Yokohama A048R Semi Slick Tires
Cruise Power Fiberglass Bumpers
Cruise Power Fiberglass Bonnet
Cruise Power Fiberglass Fenders
Cruise Power Fiberglass Rear Boot
Carbon Fiber Rear Spoiler
Downforce Diffusers
Recaro FIA Approved Bucket Seat
TAKATA Seat Belt Harness
Cruise Steering Adjuster and Shift Knob
Greddy Meters.
Nicest looking and i belive the fastest.
Can but now for
£32.495.92
Brilliant thread.
If you post images, please put the best scale of image you have to had, please do not reduce the size - be good to save them:)
YES YES YES! More of Dan and Dave ^ Anyone know of any big names in the EP history? That or general history of EP tuning and pictures etc of all EP tuners demo cars too :thumbsup:
Self set project, doing a bit of archive making.
That and working on a secret :)
Ok, if you guys have any info on the following, you WIN!
Am I right in thinking this is a Cruise demo car? If so.. was it white before?
Guesses are this is ZEP's demo... but does anyone else have any specs/info/pics of it? I'm searching but no luck is being had!
Who used the green 5door Carat as a demo model? I'm pretty sure its turbo'd?
I know I have seen this blue one before - is it a companys demo? If so, whos?
Are these EP's anything owned by companies?
The Carat was JAM's car, the yellow Soleil I think was Zeps.
That Livesport Glanza, has a V-Setup radiator/intercooler, CT9 or K1 based setup and the engine bay is pink
That Soliel (yellow EP80) was I believe Bom Maato's EP which he raced in a small car series. It used to be blue.
Thanks for the rest :)
Another Cruise weapon. I dont think any of the pink ones are demo cars, they all seem to be customer cars.
The 4E-FTE into normal TD05H. 18G-8cmウェストゲート仕様で装着。 18G-8cm Westgate specification attached. パワーFCによる絶妙なセッティングでブースト1,4で350PS/8000rpm回してもトラブルフリーです。 Power FC 2-5 in a boost in the setting of exquisite turn 350PS/8000rpm trouble free.
● Engine Relationship
4E-FTE本体ノーマル・タービンTD05H18G-8cm・SARDTYPEC-Ⅱウェストゲート・等長エキマニ 4E-FTE normal body・TD05H18G-8cm · SARDTYPEC-turbine exhaust manifolds isometric Westgate Ⅱ
●駆動関係 ●
Drive relations
TRDメタルクラッチ・オープンデフ・ Metal TRD clutch Opundefu
●サスペンション関係 ●
Suspension relationship
GABレボストⅡ GAB Ⅱ Lebost
●ボディ関係 ●
Body Relationship
メラメラピンク塗装・ライブスポーツフルエアロ・ Meramerapinku paint Raibusupotsufuruearo
●冷却関係
Cooling relations ●
八潮ファクトリーライトラジエターⅡ・ブリッツLMインタークーラーKIT・トラストOILクーラーエレメント移動タイプ・ビリオンVFC・HKTローテンプサーモ Blitz - LM Intercooler Fakutoriraitorajieta Ⅱ Yashio OIL KIT · Trust Billion VFC · HKT Rotenpusamo movement type cooler element
●ブレーキ関係 ●
Brake relations
某社危ないPAD【実例有り】 Yes - some corporation PAD dangerous example;
●吸排気系 ●
Exhaust System
マフラーエキマグGTⅡ・オリジナルエクステンション GT Ⅱ · Mafuraekimagu Orijinaruekusutenshon
●その他 ●
Other
APEXiパワーFC、ボルトオン550ccINJÃ?4・ブリッツフューエルポンプ・ウルトラMDI・ APEXi Power FC, bolt 550ccINJ Ã? 4 · Burittsufyueruponpu Ultra MDI ·
Fuck knows whats going on with the formatting.
Pink are definitely demonstrators, as they did a lot of their cars in the same shade - Skylines, Evos, AE111 Levins etc..
There's also the mid-engined Zep Racing car :)
