  • Replies 131
  • Created
  • Last Reply
Top Posters In This Topic
Geo, it is the same car but this is prior to being beige. Note how the dimples behind the sidestrips are smoothed on the beige one, wouldn't think for a second they would chisle them out again to spray it black.
That shaven one is pretty cool, but agree on the tailgate covering the lights like that look uber gay!
Ws gonna do a similar thing with a Glanza bonnet to make it fit n/a headlights, but was only going to do a subtle bady boy job, but we are going back years when that was half decent :p lol
Guest Enzo
ive got more of that, its a km design body kit
heres a few more off the old lap top
bom mateos ep82 soleil n1400 race car,
my inspiration for my current build
TC Glanza has to be added that is an awesome car.
img-resized.png Reduced: 79% of original size [ 800 x 600 ] - Click to view full imageS7300022.jpg
img-resized.png Reduced: 79% of original size [ 800 x 600 ] - Click to view full imageS7300028.jpg
img-resized.png Reduced: 79% of original size [ 800 x 600 ] - Click to view full imageS7300026.jpg
img-resized.png Reduced: 79% of original size [ 800 x 600 ] - Click to view full imageS7300016.jpg
img-resized.png Reduced: 79% of original size [ 798 x 598 ] - Click to view full imageS7300021.jpg
Engine
5E Decked Block
5E Balanced Crank
4E Ported & Mirror Polished Head
Clevite77 uprated Bearings
Pauter Forged Rods
Ross Forged Pistons
Ross Racing Rings
Cruise Power Headgasket
Cruise Power Valve Springs
JAM Racing Cams
JAM Racing Underbucket Shim Kit
SARD 550cc Injectors
Ported & Polished 5E-FHE ACIS Dual Runner Intake Manifold
4A-GE Ported Throttle body
SARD Fuel Regulator
SARD MAG+ Sump Plug
SARD MAG+ Oil Filter
Greddy TD-06 Turbo
Cruise Power Manifold
Cruise Power Downpipe
Cruise Power Screamer Pipe
Fujitsubo Power Getter Exhaust
HKS S/S Racing External Wastegate
Custom FMIC
Cruise Power FMIC Hard Piping
Walbro 255lph Fuel Pump
Clevite 77 Uprated Oil Pump
Greddy Airinx Filter
ULTRA 7mm Plug Leads
Silk Road Engine Torque Damper
Custom Polyurethane Engine Mounts
Custom Made Alloy Catch Tank
Venhill Braided Throttle Cable
Aeroquip -AN Fittings and Braided Lines
NGK Iridium IX Grade 8 Plugs
Royal Purple 10w30
All Hotpipes Thermal Wrapped
All IC pipes Reflective Wrapped
Drivetrain
OS Giken Flywheel
OS Giken T2SB Twin Plate Clutch
OS Giken Release Bearing
Earl's Braided Clutch Line
Quaife ATB LSD
TC Short Shifter
TC Cable Bushings
TC Shifter Mounts
Royal Purple MaxGear
Electronics:
Cruise Power Wiring Loom
HKS FconV Pro Gold ECU
HKS 3 Bar MAP Sensor
Modified 5v Throttle Sensor
Greddy Profec B II
Greddy Turbo Timer
Defi Link Gauges with CUII (Boost, EGT, RPM)
HKS 46 gauges (Oil Temp/Pressure)
NGK Wideband AFR
Battery relocation in boot.
Exterior:
Complete 98 Spec Factory Bodykit with Carbon Fibre Front Lip
TOM'S Sideskirts
Varis Carbon Fibre Cooling Bonnet
Carbon Fibre JAM Racing Eyebrown
98 Spec Rear Lights (Black)
Clear Side Repeaters (Black)
OMP Bonnet Pins
Carbon Fuel Door
Interior:
Cruise Power Shift Knob
Recaro Seats
NRG Billet Snap off Hub
OMP WRC Dished Steering Wheel
Carbon Fibre Glovebox
Carbon Fibre Centre Console
Carbon Fibre Binacle Surround
Factory optional arm rest
Chassis:
Kayaba SR Shocks
RS*R Springs
Cusco Panhard Rod
Whiteline Adjustable Rear Anti Roll bar
Polyurethane Front Rollbar mounts
TRD Front Upper Strut Tower
Whiteline Antilift Kit w/ Castor Bushes.
Tanabe 4 point Under Brace
ZEP Racing Floor Bar
ZEP 3-Point Rear Upper Strut
Brakes:
Levin SuperStrut Floating Twinpot Conversion
3G Discs
Endless Pads
Braided Lines
Cusco BMCS
Rolling Stock:
15" Black Work RS-Z
Toyo T1-R
Pair of 15" rims with R888s for track
Specs:
Engine (4EFTE):
*JE Forged Pistons
*TRD Metal Head Gasket
*Shot Peined Rods
*Port & Polished Head
*Polished Crank
*Custom Plenum
*100mm Throttle Body
All connected with Speed-Flow fittings and braided lines.
Ignition:
*M&W Ignitions independent coil packs
Engine Management:
*Haltech Platinum Sport 1000
*Haltech IQ3 RacePak Dash
Fuel Management:
*HKS Fuel Rail
*HKS Injectors
*Hi Flow Walbro Fuel Pump
*Peterson Fuel Filter
*SARD Adjustable Fuel Regulator
Turbo & Exhaust:
*Blitz K26 Turbo
*Blitz Wastegate
*Blitz Manifold
*Blitz 3" Dump Pipe
*Full Turbo back 3" Stainless with Hi-Flow Cat
Cooling:
*Custom Water Cooled Front Mount Intercooler
*Greddy Oil Cooler and filter removal kit
Breathing:
*Apexi Pod Filter
*Oil Catch Can with braided lines
*Stainless coolant overflow can
Gearbox & Clutch:
*Cusco LSD
*Ogura Twin Plate
*TRD Short Shifter
Suspension:
*Cusco P Zero 2 Coil-over's
*Cusco Rear Strut Brace
*Cusco Front Strut Brace
*Cusco Under Body Braces
*Cusco Brake Master Cylinder Brace
*Cusco Adjustable Panhard Rod
*Cusco Door Bars
Wheels:
*16" x 8" +10 Bronze Rota Grids
Rays wheel nuts
External Styling:
*Original Toms Body Kit
*GTiR Bonnet Vents
*Full Re-Spray in Top Secret Gold
Internal Luxuries:
*Full Leather Retrim
*Apexi EL Gauges
*Greddy Proc B spec II
*Momo Steering Wheel
*Momo Gear Knob
*Kenwood CD Player
*Full Kenwood Splits
Power: 230whp on 16psi
Probably my favorite ep ever.....
Mc Monster's project...
Low Boost 290whp @1.2 Bar
Hi Boost 320whp @1.5 Bar
Pictures
Post soonâ?¦
Engine
5E-FE Ported & Polished engine Block
4E-FTE Ported & Mirror Polished Head
Crower H- Beam Forged Rods
J.E Forged 74.5mm Pistons
Total-Seal Rings
ARP Main And Stud Kit
Cruise Power 1.2mm Headgasket
Pipers Racing 240IN/EX 8.5mm lift Cams
Cruise 550cc Injectors
Custom Made Inlet manifold
SARD Fuel Regulator
Greddy TD-05 16G Turbo
Blitz C42 External Wastegate
Blitz LM FMIC
Custom Exhaust pipes with Blitz Nur-Spec
Sard 280lph Fuel Pump
Blitz Air Filter
Hotwires Plug Leads
TRD Engine Mounts
Trust Oil Cooler Kit
F-win Alum. Radiator
NGK IRIWAY Grade 8 Plugs
Drivetrain
ORC Flywheel
ORC 309D 14T Clutch Kit
Kazz 1.5 Way LSD
4.312 Final Gear
Electronics:
Apex Power-FC Tuned By Auto Select
HKS EVC
ApexTurbo Timer
Defi Link Gauges Set(Boost,Oil Temp,Water Temp,Exhaust Temp,Oil press,Fuel Press)
HKS Engine Start Button
Exterior:
98 Spec Front Bumper
Mc Monster Carbon Lips
Mc Monster Reverse Carbon Scoop
Mc Monster Carbon Top Spoiler
Mc Monster Wider Front Fenders
Interior:
TRD Short Shifter With TRD Shift Knob
Bride Euro Seats
Bride Seat Rail
Auto Select Steering wheel
Suspension:
Tein Mono Flex
Tein Springs
TRD Anti Roll Bar
Cusco Panhard Rod
Whiteline Rear Anti Roll bar
Carbing 3 Point Strut Tower
Carbing Low Arm Bar
E'l Sport C-Pillar bar
Anti Lift Plates
Brakes:
AP 5000+ 4Pot Brake Kit
Brembo 294mm x 25mm Grooved Discs
Ferodo DS2500 Brake Pads
APP Braided Lines
Rolling Stock:
15" SSR Type-C
BS RE-01R
Some more mc_madness
Guest Enzo
its a sprnt auto test car with a 5efe in it, + cut springs ^^^^^
there are pics of the inside, hes ripped out the wheel well and most of the inner rear three quater pannels, gutted the door panels aswell as the standard fual tank,
must weight fuck all
its soo smart
the guys based in ni i think
  • 4 weeks later...
x2
i have some decent info i could submit to this thread but at the gfs.
the blue one with the massive wheels is the "SNATCH ep82"
one of the japanese starlet clubs held a track day with a field of eps.
this car scored the fastest lap by a decent 5 seconds before the next fastest starlet.
its seams the combo of massive wheels and massive turbo worked.
im gona boost up the road to get some pics of the laptop,
I think i found the times of the ep's that raced that day while searching the net
CLICK
The Snatch EP82 is 1st and zep 3rd
Heres two more links that have picks from that starlet meet in mochiya
LINK
LINK2
  • 3 months later...
have some pics and info from the cruise site B)
think these are customer cars
cruise starlet sitting outside
starlets outside cruise building
a FTE being built by cruise
address for one of the cruise building where they sell used cars etc. is
〒063-0830 北海道札幌市西区発寒10条2丁目8-10
enter it in google maps and go to street view and its win
can anyone else spot the roof lines of 2 ep82 starlets? 2nd pink car to the left infront of the building then 5th to left
