The Toffinator Posted August 9, 2010 Posted August 9, 2010 Just bought one and when im fitting it is there anything to look out for? order to do it in etc, and also anything that needs changing, i have a longer hose for the map sensor, is that it?And also i would like to decat the standard exhaust, would there be any benefit on doing this?Thanks Quote
ToyotaTech15 Posted August 9, 2010 Posted August 9, 2010 Not really much to look out for, a pretty straight forward swap to be honest, the chances are you wont have any manifold support brackets or braces that match unless you got the ones off the old car, if not it doesnt matter, i ran my old n/a with a corolla manifold and no support brackets.You might also need to make a new support for the throttle cable, depends what comes on the manifold, Only thing i would look out for is the 4 pipes going into the bottom of the throttle body, if you are changing that then just take time to out them on the correct ports again.As for the decat, it may give a small gain but if you want to up the power, the best way would be a full cutom exhaust to be honestGary Quote
ste91 Posted August 9, 2010 Posted August 9, 2010 The Corolla manifold is easy, the bolts can be awkward to get at but it's a straight forward job. Took me a couple of hours the first time I did it but the 2nd time it took me about half an hour.De-catting the exhaust should give you a tad more power up the higher end of the rev range. Might lose a tiny bit of low end torque.And it will make the exhaust sound raspier.Oh and about the throttle cable holder, some people made brackets and other complicated shit, you can just bend the one that's on there with pliers and it will hold the cable fine. Quote
The Toffinator Posted August 9, 2010 Author Posted August 9, 2010 Thanks for that, and yeh im only doing it for now until i can afford an exhaust, i just looked at the size of the cat and though it would be worth doing! Quote
ShafzC Posted August 9, 2010 Posted August 9, 2010 Toffa! Been a while mate..And sorry to threadjack but if you decat the car will it still pass its MOT? It's something I'd always wondered when I had my N/A'Shafz. Quote
The Toffinator Posted August 10, 2010 Author Posted August 10, 2010 I know mate havent spoke in a while! and im not too sure, i would hope so but if not a new cat would be in order, but i think these things should pass without one to be honest Quote
steed Posted August 10, 2010 Posted August 10, 2010 if your lucky the rubber bung for the throttle cable holder will still be on, then you can jam the standard cable on it alright. Quote
The Toffinator Posted August 11, 2010 Author Posted August 11, 2010 Thanks alot, im just unsure whether its worth decatting it.... Quote
ryan lang Posted August 11, 2010 Posted August 11, 2010 depends how long you've go til your mot Quote
Amjad Posted August 11, 2010 Posted August 11, 2010 Not worth it IMO, nice cat-back will free up a fair bit of power & response througout te rev range Quote
The Toffinator Posted August 11, 2010 Author Posted August 11, 2010 Thanks mate, i think im going to try it out for now, see how it goes, and if it makes a noticeable difference get a full system Quote
