I already have weighted gear knob,( got a accord type r one). This would be perfect little mod.
So let us know how it goes.
I think it will take a little getting used to?
Ah cool. Yeah it's a little stiffer to get into gear but I'm happy with it :)
Nice built Amjad where did you get your shift knob? looks top notch.
thanks
Thanks man! It was off Ebay, the seller does a few different designs. Mine, a ball and a longer one. Item no: 191037359598
  • 1 month later...
  • Replies 832
  • Created
  • Last Reply
Top Posters In This Topic
New exhaust video. Need to add a proper update with pics etc when I have time :)
>https://www.youtube.com/watch?v=BIqq5ki06yE
Needs screamer :ph34r:
Amjad
Sounds sweet man :)
Sounds nice :)
Cheers lads!
Nice I looked at buying one amjad but my TRD shifter still looks Shorter in my glanza
Ah sick! I'd love to see that :o
  • 2 weeks later...
*Update*
So another long overdue update, again logging the past few months worth of activities, first up the exhaust. Went to see Dean once again so finish up my RW-Developments cat back with the axle back section.
Finally got rid of the Japspeed, sounded great but looked pants. Alas it served me well for 4 years!
Old vs New
All done
For anyone who missed the last update here's a video below. I've got a few more clips to post once I've had time to edit them. Much quieter on a cruise but still roars :)
Thank you to the ID-Workz team for this little lot
New Walboro pump in
Definitely needed a new breather. Well I need a catch can, but you know. Money :lol:
Serviced again with Comma 10w50 at
People are dicks :sad:
Cheers to Morgey for sorting my new brake discs! My Yellowstuff pads were trashed with an oil leak, so will be using Blueprint pads to tide me over for a while. Still decent and I've had good results with them on track
Nearly there now! Thanks to Jezza for my JD-Tuning clear bonnet scoop blanking plate! Decided to get it tinted but as you can see didn't come out great! Ended up cloudy so I stripped it back off, but here's some pics anyhow
Here's some pics of it with the tint taken off. I'll probably get it sprayed for a subtle tint later but for now I like it.
Got a new Momo 320mm steering wheel, absolutely love it! Much smaller and feels so much nicer to drive with! I've actually got a second Momo for sale which is identical, drop me a PM!
Then I got a new lip, thanks to LukeSR for the tip on this one. Cheap and does the job
So my alternator sh*t itself last week, thanks to JDM-EP for the replacement.
Which brings me to the most recent work. Thanks again to Grant who sorted the following jobs:
-Fitting new fuel filter
-Fitting new thermostat
-Fitting new Depo oil pressure sensor for gauge
-Sorting out a spongey brake pedal (turned out to be front lines which are pretty past it)
-Fitting the new front pads and discs
-Fitting braided rear lines
-Sorting any oil leaks
-Adjusting brake line bracket which was catching under hard cornering
Brake pedal is much nicer now, and new braided lines have been ordered for the front. That's all folks!
Amjad
  • 3 weeks later...
So I decided to finally correct my preload on the coilovers. A decision I half regret because one unit has been a massive pain! Top collar was seized on the driver side front, tried cutting it off to no avail.
Ended up dismantling it to free the unit up, got a new collar coming tomorrow from BC Racing. Hopefully it fits the Meister damper!
Also took a shot of the new rear braided lines while I was at the back of the car
The original spring lengths should be 198mm/218mm F/R
Mine were 193,190 / 210,210 = F/R
Yikes! So hopefully that gets all put back on with the new collar tomorrow and I'll get a fresh alignment.
Ordered braided front lines from Tegiwa, one set got lost by royal mail and a second hasn't been delivered by DHL. Not been month at all :l
Amjad
