Dan507 Posted January 29, 2011 Share Posted January 29, 2011 Meshed turbos FTW Quote Link to post Share on other sites
miib14 Posted January 29, 2011 Author Share Posted January 29, 2011 lol Quote Link to post Share on other sites
miib14 Posted January 29, 2011 Author Share Posted January 29, 2011 things to do;2.5" systemintercooler pipe shorteningnumber plate moviingelectronic boost controllerhks actuatorturbo timergauges drilled into the dash (everytime i turn right the holder flys off to the left) Quote Link to post Share on other sites
ryan lang Posted January 29, 2011 Share Posted January 29, 2011 looks amazing dude, and the meshed turbo is why its sounds loud lol Quote Link to post Share on other sites
miib14 Posted January 29, 2011 Author Share Posted January 29, 2011 thank you Quote Link to post Share on other sites
Amjad Posted January 29, 2011 Share Posted January 29, 2011 Forgot about the meshed turbo lol Quote Link to post Share on other sites
miib14 Posted January 29, 2011 Author Share Posted January 29, 2011 haha Quote Link to post Share on other sites
miib14 Posted February 1, 2011 Author Share Posted February 1, 2011 dynowith WHP (green)with AFR (yellow)Dyno run 0.4bar114bhp @ 5349 revs115.9 lbft @ 5051 revs Quote Link to post Share on other sites
miib14 Posted February 4, 2011 Author Share Posted February 4, 2011 pics of standard exhaust system...(took them awhile back) Quote Link to post Share on other sites
miib14 Posted February 9, 2011 Author Share Posted February 9, 2011 as most of you guys know, the bottom end started to knock....so hopefully rebuilding it and get it back on the road asap so i can hear the tssssssshhhhhhhhhhhhhhhhhhh again!! lol Quote Link to post Share on other sites
ryan lang Posted February 9, 2011 Share Posted February 9, 2011 good to see you havent given up on this Quote Link to post Share on other sites
miib14 Posted February 9, 2011 Author Share Posted February 9, 2011 well thought I've had it 3 yrs... cant give up on it just yet....with the little funds that i do have left im going to try my best to get it running again... already working as many hrs as i can to fund this... but dont get paid till end of the month though... Quote Link to post Share on other sites
miib14 Posted February 11, 2011 Author Share Posted February 11, 2011 engine coming out...ready to come outits out Quote Link to post Share on other sites
miib14 Posted February 11, 2011 Author Share Posted February 11, 2011 Head seems all good.. Bottom end does want a rebuild.All bearings are showing wear... Quote Link to post Share on other sites
nastyrash 2003 Posted February 11, 2011 Share Posted February 11, 2011 i realy am gutted for u fella a fello corrola turbo owner, much better car for handling thn the starlet. u got my number if u need advice. GUTTED once again and keep up the good work, remember use 600 wet and dry on all shell caps, place the paper on a totaly flat serface and thn rub the caps with the bolt hole flats contacting the paper, + tap in the main bearing caps into the registers with a plastic hammer as the caps are a snap fit. check end float and shell crush also. Quote Link to post Share on other sites
miib14 Posted February 11, 2011 Author Share Posted February 11, 2011 thank you chris...will try and get a hold of the manual asap...hopefully there will be 2 running corolla turbos @ the manchester meet... Quote Link to post Share on other sites
miib14 Posted February 11, 2011 Author Share Posted February 11, 2011 the heads gone to clip engineering for skimming..the crank isnt bad, but he is going to pick up my old engine (n/a) and see whats the crank condition of that... if thats better then use that.... if not then this ones going for regrind... Quote Link to post Share on other sites
LukeSR Posted February 11, 2011 Share Posted February 11, 2011 Glad to see you bit the bullet and went for a new engine mate, hope your boosting again soon! Quote Link to post Share on other sites
miib14 Posted February 11, 2011 Author Share Posted February 11, 2011 thanks luke.. thought it would be easier than to buy another and run into problems again...plus i thought as most guys on here are rebuilding or got rebuilt engines may as well follow the trend lol Quote Link to post Share on other sites
LukeSR Posted February 11, 2011 Share Posted February 11, 2011 miib14 said: thanks luke.. thought it would be easier than to buy another and run into problems again...plus i thought as most guys on here are rebuilding or got rebuilt engines may as well follow the trend lol ;)Indeed, things like this put my off wanting a turbo.. But it has to be done Quote Link to post Share on other sites
miib14 Posted February 11, 2011 Author Share Posted February 11, 2011 there is a little voice at the back of my that keeps on saying " should have stayed N/A" and then theres another which says " it will be all worth it "lolsaw a 4age 20v today and thought i could have had that... and it would have been n/a with 168bhp...but turbos are easier to get more power out of... Quote Link to post Share on other sites
miib14 Posted February 12, 2011 Author Share Posted February 12, 2011 What is this number for?Read that you need it when buying bearings an shells? Or is it another number or another place? Quote Link to post Share on other sites
miib14 Posted February 12, 2011 Author Share Posted February 12, 2011 ^^Bump. Need the answer so I can order bearings. Quote Link to post Share on other sites
miib14 Posted February 14, 2011 Author Share Posted February 14, 2011 Quote Link to post Share on other sites
yaristurbo Posted February 14, 2011 Share Posted February 14, 2011 im sure thats the main journal numbering, have you had the the crank checked, as you cant get shell bearing if it wiped the crank out to much i have had that trouble when my engine got spanked. id get all them cams, head, and block all acid dipped to clean all the crap off as it looks like there been some bad opil in a some point. i may be wrong but its worth doing, trust me. only trying to help mate tell me to piss off if ya want lol.hope it all goes well for ya matey, text me if ya need and helpdanny Quote Link to post Share on other sites
