Hi guys
took my head off the other day and had to take cams out to get to the head bolts. just wondering if you can put the cams straight back in roughly how you took them out or if it needs putting in precisely in a certain way and a certain point. dont fancy putting the cams back in putting the engine back in the car and completely ruining the engine because the fuellings all messed up by dodgy cam set up lol
any advice pwease :)
got the be timed, for safety, it's 100% worth doing. set the engine to TDC for piston 1 and then use the timing marks (be careful not to mix ups the timing marks with the installation marks, they look similar).
theres usually some white markings on the side of the cam teeth you need to line them up! if youve lined all the timing marks up etc and marked the distributor position you shouldnt need to time it up! it needs to be spot on though
As above bud, to get tdc whip the spark plug out, and i normal put a bar down the spark hole and sit it on the piston, then crank the engine by hand with a 19mm rachet on the crank pully till the bar is at its highest (tdc) then line the timing mark on the crank to the arrow on the cambelt cover, just above the crank pully. Next install the cams making sure the three dots on the inside of the cam gears run in a straight line (horizontaly) this should also put the 4e hole on the cam belt gear in line with the notch on the cam cap closest to the gear, and ta da all timied in, pop the belt back on and tension the belt back up. On a side note tension the cam gear too as it prevents a rattly top end, its easy if u used a service bolt and its a bitch if you didnt, untensioned gears cause no harm just is a tad clicky wen the engine runs :) let us know if you hit any problems bud.
Also my be worth getting the timing checked by some one with a timing gun as the dizzy can drasticaly alter the timing so is important to check that properly dont just guess however that said the car can be driven to a garage etc to be checked, it wont blow up if the dizzy is out :)
just got off the phone with chris he said its easy to do and has just talked me through it all so going to do it at home next week
What a guy though knows a hell of a lot lol
Have you looked at the videos over on TGTT, shorty pointed me in that direction as i need to do my timing and was misunderstanding what people was saying without pics, im pritty much sure it will tell you step by step how to do it and all the torque settings aswell :)
Heres the link:
http://www.toyotagtturbo.com/forums/showth...gine-assembly-*
Youll have to look through the videos to find where hes fitting the cams tho lol
No worries dude, yeah i just couldnt understand what people was telling me to do without seeing pics or videos so shorty pointed me in that direction, so getting it done tonight :)
good old shorty :)
got to get my head skimmed, wait for some new head bolts to arrive then have a go myself ;)
let me know if you have any problems or if its easy just so i know :(
yep thats the guy
was going to drive down to him but he nicely said save my money and he'd talk me through everything on the phone
gave me some handy tips too what a bloke ;)
please share the handy tips if they are good as im in the same situation...
cams out,,head off,,skimmed,,ported and polished,,oh shit the cams..lol
cheers kurt
I doubt that ^ very much. I had no clue about that so called serice bolt thingy and i dont have a noisy head.
ok mate, well tell me why toyota say u need to do it? its ment to tension the inlet cam gear. i forgot to put it in when i put my cams in and it was noisy, took the cams out again, put the service bolt in (with great difficulty lol) put the cam in and it was fine.
Personally i wouldnt leave it un tentioned.
