raffa_mk Posted December 25, 2010 Posted December 25, 2010 i have bought a c-pillar bar for my ep91, i have removed the plastic covers and took the bolt out, the problem iam facing is when i put the excisting bolt through the end of the c-pillar bar and then the seat belt hehind it, it does not fit flat and i cant get the bolt through the hole, i have circled the parts it touches in the pic.Please help guys as want to get this fitted asap as it should be a simple job.Pic below. Quote
Dan507 Posted December 25, 2010 Posted December 25, 2010 Its fitted like this NOTE: you need longer bolts. Quote
Dan507 Posted December 25, 2010 Posted December 25, 2010 OR i have fitted it wrong, but use washers so it clears the clips. Quote
Sparky Posted December 25, 2010 Posted December 25, 2010 You'll need longer bolts if your keeping the seat belts, quite dangerous using a C pillar bar if your keeping the rear seats IMPO Quote
lukEp Posted December 25, 2010 Posted December 25, 2010 What c-pillar bar you got because mine fit with the plastic left on. Mines a zisco one from sikillamart and using standard bolts Quote
raffa_mk Posted December 25, 2010 Author Posted December 25, 2010 thanks Dan, What length bolts did you get? Now the problem i have is all the DIY shops are closed for today Quote
raffa_mk Posted December 25, 2010 Author Posted December 25, 2010 LukEp>>> i got from sikillamart too from the last group buy. Quote
Dan507 Posted December 25, 2010 Posted December 25, 2010 Im not sure what size mate, i just took the boolt into B&Q but, like i said, i may have fitted it wrong. if you have some washers aboutput them imbetween the braket and seat belt. that may work better. Quote
raffa_mk Posted December 25, 2010 Author Posted December 25, 2010 Yeh i would have thought it would be the other way around, going to got for long bolts and washers then,Im not sure what size mate, i just took the boolt into B&Q but, like i said, i may have fitted it wrong. if you have some washers aboutput them imbetween the braket and seat belt. that may work better. Quote
lukEp Posted December 25, 2010 Posted December 25, 2010 Here's mine original bolt goes all the way through Quote
iamlegend Posted December 25, 2010 Posted December 25, 2010 do these actually make the handling better much?waste of time tbh i think BUT they do look kool! Quote
lukEp Posted December 25, 2010 Posted December 25, 2010 Mine was super cheap but at the same time does stiffen the rear slightly. Every little helps Quote
raffa_mk Posted December 25, 2010 Author Posted December 25, 2010 Mmmm, does it make a difference if it a n/a or ep91 LukEp? like i mentioned its the 2 parts that make it not sit right and i dont think the plastic bends or flexes. will have to have another crack at it. Quote
lukEp Posted December 25, 2010 Posted December 25, 2010 Shouldn't make a difference really the EP91 N/A and turbo have same mounts/seat belts. Quote
raffa_mk Posted December 25, 2010 Author Posted December 25, 2010 guna have another crack at it now, can't stand it being stuck in the house and with shrek on the TV.... Quote
raffa_mk Posted December 25, 2010 Author Posted December 25, 2010 tried to fit it like your LukEp..... but it doesnt work for me, have a look at the first pic, sorry about the poor quality, but the holes dont line up...will have to do it like dan but remove the plastic as it looks better as shown in the 2nd pic, all i need now is the longer bolts and a few washers...really helps when you have photobucket app on the iphone Quote
raffa_mk Posted January 4, 2011 Author Posted January 4, 2011 LukEp>>>> my excisting bolts does not even go all the way through the bar end? It's a few mm's small!!! Got some bigger bolts from Bnq but one was too thick n the other was slightly slimmer and does not lock into place as thread slips... Need help guys.. Going to get intouch with skillmat guy as it's doing my nut in and loosing patience Quote
Asad Posted January 4, 2011 Posted January 4, 2011 if you want to retain the seatbelts they have to be bolted in BEHIND the c-pillar bracket not infront in an accident the bolt will just shear off = no goodlukeEP has it fitted rightdont think many people can help as c-pillars buyers are usually people who`ve stripped out the back so its an easy fiti dont see the gains with such an item tbf Quote
Wantaglanz Posted January 4, 2011 Posted January 4, 2011 wouldnt people who sit in the back, hit their head on this? :S Quote
_shaun_ Posted January 4, 2011 Posted January 4, 2011 id just drop keith a pm and ask for the right bolt size that way u no exactly what bolt u need mine would of fitted fine with the bolts that were supplyed but i striped rear for cage anyway Quote
lukEp Posted January 4, 2011 Posted January 4, 2011 looks like the holes not far off ust bend the plastic tabs slightly if you look at mine the look slightly bent, no body hits there head its to far back or my kids aint that tall yet. i got mine second hand andIt fit straight away, It makes a difference if you tighten it up as much as you can, if you just fit it so the bars not tight it wont do anything! Quote
starlet666 Posted January 5, 2011 Posted January 5, 2011 bracing body parts doesnt actually work unless it is triangulated.... it looks good, but it wont do much else..... simple physics means they cant do bugger all..... more so when they have moving rose joints on them..... Quote
