siren676 Posted December 29, 2010 Posted December 29, 2010 I recently did a cooling system flush and noticed that when i refilled it, it only took 2 liters of coolant mixture(1L anti-freeze, 1L water).Is this right? Quote
Driver Posted December 29, 2010 Posted December 29, 2010 run engine for abit and keep topping it up, youll only be filling rad untill thermo is open Quote
Russleh Posted December 29, 2010 Posted December 29, 2010 plus ul be suprised at how much water will be sittin in other bits of the engine if it wasnt completely empty. Quote
siren676 Posted December 30, 2010 Author Posted December 30, 2010 run engine for abit and keep topping it up, youll only be filling rad untill thermo is openI did that and it didnt take much more even with the temp gauge sitting on 1/2 way.I filled the reserve tank to the full point and went for a spirited drive and it still barely took any out. Quote
Driver Posted December 30, 2010 Posted December 30, 2010 Wouldnt worry about it then if its full of water/coolant/antifreezeCheck it every now and then (which you should do anyway) and keep an eye on your temp (again as you should) and it should be fine Quote
lukEp Posted December 30, 2010 Posted December 30, 2010 To bleed a cooling system I remove rad cap start the car make it fast idle and wait for the rad fan to kick in and out a few times while keeping an eye on the level put cap back on fill overflow up an turn engine off, as the engine then cools the system will suck and water it needs out of the overflow tank Quote
siren676 Posted December 30, 2010 Author Posted December 30, 2010 To bleed a cooling system I remove rad cap start the car make it fast idle and wait for the rad fan to kick in and out a few times while keeping an eye on the level put cap back on fill overflow up an turn engine off, as the engine then cools the system will suck and water it needs out of the overflow tankI think i did that, but i went for a trip to the dairy and back before i turned off the car. Quote
enzo_e492901 Posted December 30, 2010 Posted December 30, 2010 Did you remove the drain plug/bolt thats in the block as well as the one in the bottom of the rad? If you don't remove the one out of the block a lot of old coolant tends to stay traped in the block. I believe capacity is just under 5L something like 4.5L I think.Gavin Quote
