Nanglebadger Posted February 28, 2011 Posted February 28, 2011 Right,I need a definitive answer here folks.Does anyone have a steering wheel boss kit, or a link to one, that is EP91 specific, in other words, i need it to allow the steering wheel HORN button work!i dont want to have to fit some remote piece of crap.so, is there a kit to allow this or not??Links please to DEFINITIVE EP91 kit solutions. No hypotheses please folks! needs to be 100% certain.Phil. Quote
ryan lang Posted February 28, 2011 Posted February 28, 2011 this is the 1 i have, and my horn button works, http://www.rhdjapan.com/boss-kit-hub-adapter-toyota-18721but you have to buy this horn just for the sexualness of it http://www.rhdjapan.com/hkb-sports-origina...ld-silver-58282and because i have the same but in black and it definitely works,just fit the boss kit and then plug the wire into the horn it doesnt wrap around anything because of the metal plate that connects on the back of the bossthis TRD 1 will work alos as it only has 1 connector on the backhttp://www.rhdjapan.com/trd-steering-wheel...ton-black-18856 Quote
lukEp Posted February 28, 2011 Posted February 28, 2011 You can have mine but it's nardi fitment only? Quote
Nanglebadger Posted February 28, 2011 Author Posted February 28, 2011 its a Bride replica wheel Luke mate, 280mm, so i doubt it will fit.Ryan, u are a star! look like im gonna have to splash the cash for a new one then!one more question however, was your EP91 an airbag model?Phil. Quote
Nanglebadger Posted February 28, 2011 Author Posted February 28, 2011 BUMP for Ryan again!was urs an airbag model dude??Phil. Quote
ryan lang Posted February 28, 2011 Posted February 28, 2011 the boss kit? no its notive got the snap off kit on there now too, that was a bitch to wire the horn up too though lolalso my indicators didnt self cancel after fitting it until yesterday that is lol Quote
Nanglebadger Posted February 28, 2011 Author Posted February 28, 2011 so in other words, this kit is no use with an airbag model EP91???seems like there's no kits available at all then.eeeuuugggghhhhh...steering column change....fuck that.Phil. Quote
ollie ryan Posted February 28, 2011 Posted February 28, 2011 http://cgi.ebay.co.uk/Toyota-MR2-Celica-Gl...=item3a6373ee6fthis one is supposed to allow the horn to workdan has one in his red glanza s and he said his horn works Quote
ryan lang Posted February 28, 2011 Posted February 28, 2011 oh, i had an airbag in my oem steering wheel if thats what you meant lolthe airbag works from shock its not wired into anything at all that i know of dudeit was just a simple take the old wheel off, stick the boss kit on stick the aftermarket wheel on then plug the wire that comes attatched to the boss to the horn and walla! tooting like road runner but the horn needs to be fitted properly because theres a copper wire thing that comes from the horn that needs to make contact with the boss for it to beep. ill get pics tomorrow for you dude i got sod all else to do anyway ill make a 'how to' guide tomorrow and we are even on the lecture front haha Quote
lukEp Posted February 28, 2011 Posted February 28, 2011 I know of two different air bag system in glanza's mine the wire and clock spring type and Craig n has a wireless type which works on a weight in the air bag he light never even came on when a removed his airbag so dilemmas dude.Fuck Ryan beat me to it I'm thinking Phil has the same type as me with a clock spring and wires Quote
ryan lang Posted February 28, 2011 Posted February 28, 2011 its frustrating how far away you are otherwise i would do it for you Quote
LukeSR Posted March 1, 2011 Posted March 1, 2011 http://cgi.ebay.co.uk/Toyota-MR2-Celica-Gl...=item3a6373ee6fthis one is supposed to allow the horn to workdan has one in his red glanza s and he said his horn worksThat didn't work for me, I've ended up putting a push button for my horn Quote
Nanglebadger Posted March 1, 2011 Author Posted March 1, 2011 looks like its no use then as we have the different airbag systems.this is f**kin gay. gonna have to get a button. fail.Phil. Quote
ryan lang Posted March 1, 2011 Posted March 1, 2011 did you have the OEM 3 spoke wheel or 4 spoke wheel? Quote
ryan lang Posted March 1, 2011 Posted March 1, 2011 here you go dude, aslong as your boss kit has this gold ring around the back:and 1 wire coming from it to the front of the boss like this: mine is green, doesnt matter what colorit should work, because the gold plate is pressed against:then you fit your wheel to the boss kit, the boss kit onto the spline, pull the green wire out through the centre and plug it into the single connector on the back of the hornthe v-shaped gold connector need to be touching the boss kit for the horn to work, and the boss kit comes with a little spacer ring that sits between the boss and the wheel for the v-shaped gold connector to touch.aslong as you buy the same boss kit and horns i have linked you to in my 1st post its easy as pie Quote
lukEp Posted March 1, 2011 Posted March 1, 2011 see the little gold pin that touches the gold ring on the boss....... he dont have that pin he has a clock spring which is basiclly a coil of wire in a round case and as you turn the wheel the wire unravels/ravels up to keep that connection there which is the same as mine you need a totally different boss for our setup he needs this onehttp://www.rhdjapan.com/boss-kit-hub-adapt...ed-toyota-26432 Quote
Nanglebadger Posted March 1, 2011 Author Posted March 1, 2011 LUKE U SEXY SEXY BASTARD.HOWEVER, HOLY SHIT! could that be any more exspensive! £100 for a boss kit for a £20 wheel! yikes!can't see how it works exactly, but it specifies EP91 Airbag model! thats the ticket right there!Phil. Quote
lukEp Posted March 1, 2011 Posted March 1, 2011 Yeh which is why I don't have one £100 I'd rather keep the original wheel TBF. Quote
Nanglebadger Posted March 1, 2011 Author Posted March 1, 2011 aye or another £80 will get u the TRD one off Gryzor on TGTT!! which i always wanted, but i aint got £180!so, Bride 280 mm with no boss kit, just straight to the hub, for instant stalk flickage, and a light-up blue button. winz.Phil. Quote
rob_bower Posted April 4, 2011 Posted April 4, 2011 been having a look in to this might have found away around the problem!! will update once i finished!! Quote
Shyam Posted June 13, 2017 Posted June 13, 2017 been having a look in to this might have found away around the problem!! will update once i finished!! Did you manage to find a way around this? I've just fitted the boss with contacts and my horn has a push in spring mechanism. Thanks Quote
