Well since rotating my turbo i can no longer adjust my actuator above 0.3bar unless i get a bracket made up for it. I was considering my other options and had a quick read on MBC's and EBC's. Are the MBC's on ebay a total no go like the manifolds? Heres a link of one of the egay ones: Ebay MBC
they are utter shite my car had one and would boost creep all the time even when gauge showed 0.5 i brought the car with it on drove round the corner n ripped it straight off and car runs fine sice
how much you got to spend on a ebc mate?
Well i've just bought one of those cheap MBC's for £6 just to try it out (only £6 :)). Not expecting good results but i just need something to see more running a lot more than 0.3bar because i'll be running far to rich. If this MBC and the new bracket on the actuator doesn't help me at all i may try and swap my Varis front for a half decent EBC. Any recommendations?
Im literally only going to be running that for a week, maybe less, just can't be running that low on boost when the fueling is set up to be running 0.8bar. Ye i was looking at those Gizzmo ones earlier! I think that will be the one i go for if i decide to get one :)
mate if you get a gizzmo get the MS-IBC, i just did and it looks sweet, my car is on road from next week so i can review it for you then if u like
Ye mate definitely, let me know how you get on :)
Jamie - Sure someone has got a Gizzmo ebc on here in a breakers thread.... check it out. There is a few Profec Spec 2s on the bay at the mo. Can't go wrong with those i have one as you know.
Ive got the black one mate with the blue led display its a good piece of kit
this sounds like the MS-IBC 6 memory functions 3.5bar max etc im geting me one next month wahoo
is it accurate? you running an ecternal setup?
I'll have a look into these as well Marc :)
I've got a jam FCD installed so don't need to worry about that. Going to set the shitty MBC to around 0.5-0.6bar to try and compensate for the inevitable boost creep. Only be running this for a few days so should be ok :)
ahh ok na i read above about u mentioning that u can fuel to .8 of a bar but was thinkin that standard management can do that :p. cant u just get a hks actuator n make up a bracket?? b cheaper and easier??
my bad just read the previous posts :p
The actuator i've got is an uprated one (as its adjustable) just unsure on what make. There would be no point in me buying an hks and then making a bracket when i can just make a bracket for the one i've got. If i make a bracket and the boost is still unaffected though then this may shout out the actuator is at fault. Then i'll be looking at buying an HKS one :)
i had the gizzmo and they are hard work. just cheap units if you ask me i had it on for a week and got sick of it. all blitz ebc are the bom
explanation on how they are hard work?
cheap units ne ways....
Gizzmo sounds like a good shout im after EBC at the mo but getting mixed reviews on the gizzmo and there seems to be so many different types but they all look the same!
save your self some pennies
http://cgi.ebay.co.uk/Gizzmo-Boost-Control...=item56429f086e
got mine from there,next day delivery,excellent!
defo spend some money on a ebc one of the best things i have bought for my tdo4 set up and the gizzmo work a treat on external wastegate set ups.
ahh no doubt mate ebc is a must purchase!! but hes only running 0.3 bar starting pressure, the ebc would be maxed out trying to hit 0.8. better of sortin the actuator 1st.
