Lukew360 Posted March 27, 2011 Posted March 27, 2011 1. What are the Pros and Cons of not using the 2 O2 sensors in the cat?There's a lot of "soot" in my exhaust, I think it's running a bit rich - think it might be a Lambda sensor? 2. Plug and Play ECU, Can I run it with my standard exhaust manifold and top mount cooler? Or should I wait until I fit the FMIC and manifold? Thanks in advance! Quote
ro55ifumi Posted March 27, 2011 Posted March 27, 2011 Wait until you fit the mani and fmic mate Quote
Lukew360 Posted March 27, 2011 Author Posted March 27, 2011 Was afraid that would be the case! I can't wait to fit it but I'll hold out Will have the mani fitted pretty soonish, still need to get hold of a decent fmic that doesn't require to much butchering.Still not recommended to run the ECU on a TMIC? Quote
Amjad Posted March 27, 2011 Posted March 27, 2011 I ran it on TMIC for a bit. Works well but the thing is in 4th gear and above you will REALLY notice heatsoak/limp mode and the need for a FMIC!Once FMIC was fitted it flew Quote
iamlegend Posted March 27, 2011 Posted March 27, 2011 do it right do it once, fit all the parts needed first then plug the ECU in and then enjoy! Quote
Lukew360 Posted March 27, 2011 Author Posted March 27, 2011 Cheers guys, I'll wait now Anybody know about the 2 cat sensors? Lambda and O2 Quote
Amjad Posted March 27, 2011 Posted March 27, 2011 What about them? Lambda is the O2 sensor and you'll need it for a decat.The lower sensor is temperature I think, and not really needed I don't think as mine runs fine without it Quote
Lukew360 Posted March 27, 2011 Author Posted March 27, 2011 What about them? Lambda is the O2 sensor and you'll need it for a decat.The lower sensor is temperature I think, and not really needed I don't think as mine runs fine without itWell can I run it without it? Or will it run shit/bad mpg?It was question number 1 Quote
Amjad Posted March 27, 2011 Posted March 27, 2011 Yeah I don't think it'll run properly, why do you ask? Quote
Lukew360 Posted March 28, 2011 Author Posted March 28, 2011 Well basically I think I might have a iffy Lam Sensor, the cars running rich.You can smell it and my fence is black from where I start the car up in the morning lolSo I guess I'll replace it now Quote
Lukew360 Posted March 28, 2011 Author Posted March 28, 2011 lol Cheers Amjad, can anyone else input on this?Want to be sure it is the Lambda sensor before I change it Quote
_shaun_ Posted March 28, 2011 Posted March 28, 2011 Mine and drivers ran fine with out the lamda sensor he had an emb and i used a blitz acess however am getting mine fitted back on today as it is messing with the idle now i have a emu Quote
starlet666 Posted March 28, 2011 Posted March 28, 2011 mine runs sweet without both sensors im running an emanage ultimate and have a wideband fitted instead and have it plugged into the EMU to self tune Quote
Lukew360 Posted March 28, 2011 Author Posted March 28, 2011 Well going by this I'll try mine without the sensor before I buy one Thanks for all the help Quote
