Few quick questions ;)
1. What are the Pros and Cons of not using the 2 O2 sensors in the cat?
There's a lot of "soot" in my exhaust, I think it's running a bit rich - think it might be a Lambda sensor?
2. Plug and Play ECU, Can I run it with my standard exhaust manifold and top mount cooler? Or should I wait until I fit the FMIC and manifold?
Thanks in advance!
Was afraid that would be the case! I can't wait to fit it :blush: but I'll hold out :(
Will have the mani fitted pretty soonish, still need to get hold of a decent fmic that doesn't require to much butchering.
Still not recommended to run the ECU on a TMIC?
What about them? Lambda is the O2 sensor and you'll need it for a decat.
The lower sensor is temperature I think, and not really needed I don't think as mine runs fine without it
Well can I run it without it? Or will it run shit/bad mpg?
It was question number 1 :blush:
Well basically I think I might have a iffy Lam Sensor, the cars running rich.
You can smell it and my fence is black from where I start the car up in the morning lol
So I guess I'll replace it now
