started to get a really high pitch whine from turbo but it still pulls as hard and no smoke any ideas what it could be also the high low boost solanoid has started to make a clicking noise when you turn ignition could it be related ??????
The clicking noise you can hear is the abs pump every glanza i have owned has done the same thing soon as you turn the key and leave it for 2secs it make a buz type of noise....As for the high pitch noise as said it could be a leak have you checked the boost gauge to see if she is still boosting as she should?
Its definately not ABS...... its def turbo related, sounded like a walbro fuel pump high pitch sound, It was really loud.
Ollie and I could hear it in front!
are you sure its not the bearings mate?
Was nice to meet you anyways Lewis! Your car looks Savage!
deffo boost leek. Try putting it in 4th/5th gear at about 40 and listen to the spool up. This should confirm it. Hope this helps
Joe
just been revving it and it sounds like it is coming from the air filter so i took it off just left the relocation pipe on and it def sounds like its comin from there any more help ?????? please
my first hybrid did this and dropped boost after reaching .8 bar. How is it boosting buddy?
turned out my turbo was fucked not sure what happened but the balancing was way out and it was the compressor wheel hitting the inside causing the screeching noise
mine does this too, but only at very high revs, like not far from redline. its just like a whistling sound, sounds like air escaping somewhere or something.
its boosting fine matey and no smoke what so ever im really confused now ?????
mine does it as soon as you touch the pedal even at really low revs and boost ????????
no mine doesnt suffer from that. there is a chirping sound on tick over though, turned out to be the oil breather, but i've just left that.
im not saying what happened with mines is whats happened to urs, just saying it sounds like it. pop your air filter off and check for play in the shaft/ damaged blades etc go around all intercooler pipes and make sure everything is tight aswell
mine sounded like it was the air filter lol turned out it was the intercooler pipe under the rad. have you got the over the top type piped front mount. thats what i had.
yeah over the top mate
ok mate will do thanks
i spoke to a mechanic about this today mate and he said it sounds like a blade is chipped and put the turbine out of balance
might be worth taking the turbo off and checking the blades over
Alright mate, sounds like a chipped blade or the turbo bearing.
If you find out your turbo is fu**ed then I've got one for sale just let me know
Cheers
