need to refit my rocker cover and just wondering if they are any torque settings for them to be in?
every time i fit these they ALWAYS leak :D:D
using new gasket and new washers/nuts...
Im sure there is a DIY thread on here or Toyota GT Turbo about painting your rocker cover and the Torque settings are in there :D
Also when changing the Rocker Cover Gasket, i got told to clean the surface free of crap and put a little gasket silicone sealers in the corners where theres the little bridge bits that hold the cams in place, hard to describe really, but i did this and have no leaks what so ever :D
aslo worth noting maye be worth getting the gaskets that go round the spark plugs aswell.
as when i first fitted mine i got a new cover gasket but mine leaked around the spark plugs. got the spark plug gaskets problem solved. and ye you need a tiny bit og sealent on the corners of cam carriers
Are people checking the torque settings once the cars had a good run out.. i always nip mine up abit as the rubber crushes even more with the heat, i've never had one leak yet :lol:
