kbond Posted May 26, 2011 Posted May 26, 2011 i bought a fte throttle body and gen1 corolla manifold off of miib14 not long ago and recently tried fitting it to my n/a, the manifold went on fine but i cant get the throttle body to run properly for example not ticking over and when it does it revs really high, the engine management light is always on, and the plugs are different for the throttle position sensor is that anything to do with it? if so how do i get around this as i have heard this does work and it is a good gain for an n/awould really appreciate it if anyone can helpkeiran Quote
rob_bower Posted May 26, 2011 Posted May 26, 2011 chris is the man to speak to nastyrash2009 or somwrhing like that!! drop him a pm im sure he'll be happy to help!!Rob Quote
kbond Posted May 26, 2011 Author Posted May 26, 2011 chris is the man to speak to nastyrash2009 or somwrhing like that!! drop him a pm im sure he'll be happy to help!!RobWill do, cheers!Keiran Quote
ali_legend Posted May 26, 2011 Posted May 26, 2011 Yh man chris is defo the dude to speak to. Im pretty sure no other tb fits on the rolla mani as i have a rolla mani in my car mate. Could be wrong, best bet is to pm chris Quote
redz11 Posted May 26, 2011 Posted May 26, 2011 try adjusting the TPS (throttle position sensor on the side of the TB) this happened when we fitted it for the first time to my old n/a(was the TB off an auto? think the sensor has 1 extra pin for the auto? someone will confirm or say im wrong i really cant remember)you will enjoy the gains Quote
miib14 Posted May 26, 2011 Posted May 26, 2011 as everyone has said, chris is the best person to talk you through it...and ali he has my old one. its from the first gen corolla 4efe and is more or less exactly the same manifold as the turbo one Quote
redz11 Posted May 26, 2011 Posted May 26, 2011 as everyone has said, chris is the best person to talk you through it...and ali he has my old one. its from the first gen corolla 4efe and is more or less exactly the same manifold as the turbo oneyea definatly contact chris i had that exact setup on my old n/a loved it Quote
ryan lang Posted May 26, 2011 Posted May 26, 2011 the gen 1 corolla mani is the same as the fte mani, and the auto tps has 4 pins so wont work on the n/ayou need to get hold of a manual glanza tb bud. unless chris knows a way around it, but knowing him he probably does lol Quote
nastyrash 2003 Posted May 27, 2011 Posted May 27, 2011 just got in from the night shift now fella, did u get the TB and mani complete off mibb. if so it should be set up. will pm u my number. give us a bell. also wat year is your starlet. Quote
kbond Posted May 27, 2011 Author Posted May 27, 2011 cheers for that everyonehad a good long chat with chris and im gonna have a go at fitting it tomorrow! keiran. Quote
nastyrash 2003 Posted May 28, 2011 Posted May 28, 2011 cheers for that everyonehad a good long chat with chris and im gonna have a go at fitting it tomorrow! keiran.sorry if i dribble on a bit mate. right things i need to know = wat ignition system u running, wat pin plug is your starlet TB (pic if ness), check all vac pipes inplace (fuel reg always gets left out). new gaskets needed (use gasket paper for the TB, as its dead easy to cut with stanly). also unscrew your idle valve off your oldTB and plug it back in and tie it up some wer under bonnet, its located under your starlet throttle port 2x philips screws. chris Quote
