brianmccourt Posted May 30, 2011 Posted May 30, 2011 here it is ere now thats it there has evo4 sideskirts gt spoiler lowered have the gt engine there gettin new piston rings took out aircon fitted the small intercooler gt back bumper have the sump ready from ep85 too so thats it there it goes good was mini drifting with 4efe and no diff so should be good with the diff welded and turbo enginealso the vicous shaft that needs made solid Quote
brianmccourt Posted May 30, 2011 Author Posted May 30, 2011 did anyone ever kill a ep85 gerbox???or rear diff ect?? Quote
EP91Bon Posted May 30, 2011 Posted May 30, 2011 YOU SIR ARE A MUPPET JUST BECAUSE I WRITE UP ABOUT A PROJECT I AM DOING YOU TRY TO BE SMART WHAT DO YOU HAVE PROB NOTHING ONLY YOURSELFOOOSH OOOSH OOOSH dont get your knickers in a twist Quote
GAZ@A&G_TUNING Posted May 30, 2011 Posted May 30, 2011 good work man , so whats the story with this car then, what ya done or broke to have it rwd? Quote
brianmccourt Posted May 30, 2011 Author Posted May 30, 2011 good work man , so whats the story with this car then, what ya done or broke to have it rwd?tell you the story behind it now... friend of mine got it for 400 he put new wheel bareings in to it 4 new tires cleaned her up a bit he tried everything to make it rwd and failed so sold it because it was kinda slow ha 4efe.. so he sold it to paul first poster on this topic he had it only 1 nite and he noticed all of a sudden it was rwd no noises or bangs so he had it for 3 months was doing roundabouts in the wet ha ha let it run low on oil bigends went then i got it for 250euro had a evo 4 for breaking used sideskirts got a gt engine loom clocks [i dont need] fuel pump coil for 200 so its not as if i am at a big loss i love starlets always had one will always have one...ever since seen my friends ep85 fully gt converted always wanted one but too hard to come by....this may do now ha its really just a runaround have a evo as my proper car...thats it now also the car is not any slower rwd still a nippy little car close gears is cool is there anyway to convert a 4wd to rwd??? Quote
Galliano Posted June 8, 2011 Posted June 8, 2011 LOVING PAULS TYPING BECAUSE HE CANNOT USE ANY FORM OF PUNCTUATION AND HAS TO SHOUT TO EMPHASISE THE FACT HE IS ONLY SHOUTING IN ONE FULL SENTANCE FOR THE FACT THAT HE HAS LOTS OF STUFF ON HIS CAR THAT MAKES HIS AMAZING AND HAS A PROBLEM WITH OTHER MEMBERS WANTING TO SEE HIM STOP SHOUTING AND.....Ok I'm bored of it now. Anywhos, cool stuff going on here, strange how it was "all of a sudden" RWD though. Quote
Guest Enzo Posted June 8, 2011 Posted June 8, 2011 tell you the story behind it now... friend of mine got it for 400 he put new wheel bareings in to it 4 new tires cleaned her up a bit he tried everything to make it rwd and failed so sold it because it was kinda slow ha 4efe.. so he sold it to paul first poster on this topic he had it only 1 nite and he noticed all of a sudden it was rwd no noises or bangs so he had it for 3 months was doing roundabouts in the wet ha ha let it run low on oil bigends went then i got it for 250euro had a evo 4 for breaking used sideskirts got a gt engine loom clocks [i dont need] fuel pump coil for 200 so its not as if i am at a big loss i love starlets always had one will always have one...ever since seen my friends ep85 fully gt converted always wanted one but too hard to come by....this may do now ha its really just a runaround have a evo as my proper car...thats it now also the car is not any slower rwd still a nippy little car close gears is cool is there anyway to convert a 4wd to rwd???good to see another starlet nut finding these forumscheck here on how to convert the ep85 to fr layout,easy if you can find a middle prop to replace the viscusthe corona part is discontinuedhttp://www.ukstarletclub.com/forums/index....mp;#entry570218 Quote
ro55ifumi Posted June 8, 2011 Posted June 8, 2011 Geo... his name is Brian not Brain Nice little project you have going on John Quote
brianmccourt Posted June 9, 2011 Author Posted June 9, 2011 thanks lads i cleaned up the engine and rocker cover and intake wire brush drill head done some job also started stripping the engine loom and 4efe engine out will get pics later tomoro also got the frontmount sitting properly well best i couldwas reading site above some good info on fr setup is the carona shaft a solid bar?? no vicous on it?? Quote
brianmccourt Posted June 14, 2011 Author Posted June 14, 2011 FOUND OUT WHY ITS RWD FRONT DRIVERS DRIVE SHAFT HAS POPPED OUT ABOUT HALF INCH PUT IT BACK IN AND IT WAS GRAND TOOK THE 4EFE OUT TODAY GEARBOX IS DRY EVERYTHING SEEMS 100% SO FAR Quote
Stulet-GTT Posted June 14, 2011 Posted June 14, 2011 Is it me or does it resemble a scooby wagon???But i do like the look of this, nice little project... Quote
brianmccourt Posted June 22, 2011 Author Posted June 22, 2011 done a bit with this also found this here is the car http://youtu.be/JWdrTEprthcposting this here as its so hard to find info about this chaced the vid up and found the site in japan the lad shows how to convert the el45 corsa to rwd here is the shaft that has the viscous coupling on it made solidnext take out the front shafts but only the bar and inner joint next you have to use the outer joint to hold the wheel and bareing together you can use a old cv joint as it does nothing only hold it togetherthe car in the vid only has trd coilovers boost turned to 0.7 and full exhausthere is a pic of the caranyway i got a bit done with my one got the non turbo engine outcleaned bit of rust around the battery traycleaned the bay too [not done fully yet]next i got this bad boy outand done this #next on the line was sump i have to keep the ep85 one but it has no oil return????was a dope and let the engine fall and it landed on the ecu connection of the new loom and smashed it to bits so i used the 4efe plug and had to pin it out was sick!!!!also removed power steering dont like it in rwd cars or in starlets anywaysalso got the intercooler sitting good tootook the 4efe rods and pistons out and they are thicker than 4efte ones ??? and pistons are same too same numbers on them and everythingturbo on left and non turbo on right Quote
Guest Enzo Posted June 22, 2011 Posted June 22, 2011 aye is that a glanza 4efte? would explain the thinner rods Quote
brianmccourt Posted June 22, 2011 Author Posted June 22, 2011 aye is that a glanza 4efte? would explain the thinner rodsnot sure man it came from a gt can ya tell from the engine number?? Quote
Guest Enzo Posted June 22, 2011 Posted June 22, 2011 nofrom 95 onwards the 4efte was revised having na rods which should explain it if it came from an advance Quote
brianmccourt Posted June 22, 2011 Author Posted June 22, 2011 nofrom 95 onwards the 4efte was revised having na rods which should explain it if it came from an advanceit was a 95 car alri are the pistons the same??? they show no difference at all??? also are piston rings same???i have to buy a new headgasket now and i have my mobile mechanic to come build the engine back up for me Quote
Guest Enzo Posted June 22, 2011 Posted June 22, 2011 i wasent aware the pistons were the same, if they are thats grewat news, i have the same engine means that the compressions is adjusted by the headgasket thicknessscore thanx for sharing your info and pics on the pistons. Quote
brianmccourt Posted June 22, 2011 Author Posted June 22, 2011 i wasent aware the pistons were the same, if they are thats grewat news, i have the same engine means that the compressions is adjusted by the headgasket thicknessscore thanx for sharing your info and pics on the pistons.no bother man they look the same anyways Quote
Idrees Posted November 28, 2011 Posted November 28, 2011 Very nice job, I'm so glad you got rid of those horrible corner pieces that were on the rear bumper! Really needs a proper intercooler now Quote
ryan lang Posted November 28, 2011 Posted November 28, 2011 i wasent aware the pistons were the same, if they are thats grewat news, i have the same engine means that the compressions is adjusted by the headgasket thicknessscore thanx for sharing your info and pics on the pistons.no bother man they look the same anyways they shouldnt be the same :/i have an n/a and glanza engine, and the pistons are different ill get some pics tomorrow because i gotta go down the the garage Quote
PaulStarletSR Posted November 28, 2011 Posted November 28, 2011 likin the new rims but u need to work on the paint,looks like a bad rattle can job, patchy in places.get sum vidz up of it driftin m8y Quote
Sparky Posted November 28, 2011 Posted November 28, 2011 Yes both the pistons look like n/a high compression ones to me, the glanza ones dont have the lump in the middle like the n/a ones Quote
