Kirsty Posted August 16, 2011 Share Posted August 16, 2011 Just fitted relocation kit and its now spiking at 12psi throwing on the engine management light. i take the engine management light is due to the boost? is there anything i can do? the car has got full stainless (cat fitted), 1st and 2ndboost mod and thats it. help please?, was boosting at 10psi pre relocation kit. its goes to 10psi but then spikes to 12psi. am i going to cause damage? and how do stop the light coming on?thankskirsty Quote Link to post Share on other sites
lew777 Posted August 16, 2011 Share Posted August 16, 2011 you got a fcd? Quote Link to post Share on other sites
Kirsty Posted August 16, 2011 Author Share Posted August 16, 2011 no but hasnt hit fuel cut, just keeps on going so know it hasnt hit it Quote Link to post Share on other sites
Amjad Posted August 16, 2011 Share Posted August 16, 2011 Sounds like it's creeping and hitting fuel cut to me, do a diagnostic check and see what code comes up Quote Link to post Share on other sites
Dean @RW-Developments Posted August 16, 2011 Share Posted August 16, 2011 does sound like signs of fuelcut especially with the engine managment light coming on. have you got a boost controller or hks actuator so you could turn the boost down slightly? is common for it to creep when doing filter, exhaust and intercooler upgrades with the ct9Dean Quote Link to post Share on other sites
H_D Posted August 17, 2011 Share Posted August 17, 2011 Definatly sounds like boost creep and fuel cut which is common when re-locating the the air filter to the front,1) I would definatly get the wastegate ported on the turbo to eliminate boost creep,2) get a FCD and FPR or an aftermarket self learn ecu which will remove fuel cut, speed cut and raise rev limit etc3) change your manifold to an aftermarket one if you are still using the stock one as 1bar on a stock manifold will kill your engine eventually i.e melted 3rd piston.Hope this helps! Quote Link to post Share on other sites
Socks Posted August 17, 2011 Share Posted August 17, 2011 glanza's put the eml on when they get close to hitting fuel cut, but not actually hitting it....so yeh your problem is creep and the ecu is doin its job in protecting you from overboosting. you may find it gets worse at night/when its colder... Quote Link to post Share on other sites
Gainzy Posted August 17, 2011 Share Posted August 17, 2011 I have a fcd if you wana buy one £38 posted superchips ABC one Quote Link to post Share on other sites
