just wondering what bits from the 4efte i need for the engine swap. can i use n/a ignition coil etc. what ancillaries do i need from the 4efte apart from loom?
another topic but need advice! engine swap is iminent!
If your good with wiring, really all you need is the FTE engine and loom, you can mate that to the n/a loom and away you go :D
You dont need turbo shafts/rads/lines/gearbox ect.
+1. Turbo engine loom spliced into the N/A fusebox and interior plugs.
You'll need to buy a ignition amplifier, igniter and the map sensor from a 4E-FTE (2 different versions depending on ep82/ep91) The ignition from the N/A and turbo is also different. The 4E-FTE requires a King Lead which you will also need to purchase.
Thats pretty much it. Everything else bolts straight on.
