Engine starting to sound tapety!
Since the blast down to JAE my engine has started to sound very tapety under strain! At first I thought it might just be low on oil but it was only 1/2 way between min and max so topped up but no better!
Anyone got any suggestions? Or is it time to start thinking rebuild?
Rob
Turbo time.........Is it al the time or just at startup and certain RPM?
My SR made a rattling sound on start up and from aboue 2.5k-4k only when under load and it turned out to be shells due to the oil seive clogging up
I wouldnt flush it unless your 100% certain all seals and the engine are healthy may just make things worse
whats the mileage on it? Any recent work? What were your oil change intervals?
Check the all the fluids again, have a look thru the engine bay for anything loose check the crank pulley too its been known to split...if you cant find anything leave it be n monitor it n/a units are cheap and easy to pick up...you dont want to pull it apart and crate more work for yourself
  lew777 said:
turbo it :)
:) if dies!
just coming up to 105K its due a service now gets done every 6 months regardless of mileage doing about 12-14k a year! couldnt see anything when i checked but ill give it another once over tomorrow if not i might just drop the oil anyway!
yeah drop the oil and while your there have a good poke around if not dont worry too much about it my old one had 110k and i drove it like i stole it never missed a beat....you keep ontop of maintenace so yours should be grand.....on a side note you may want to change the timing belt now if it hasnt already been done
