iamlegend Posted November 24, 2011 Posted November 24, 2011 right seen lews thread of compression results i thought i would take my oil cap off and see what happens, well let it get to temp,took the oil cap off and it spits oil every were and puffs air out of the hole also making a low whistle kinda sound? now surley this is not normal????? it does not smoke out of the exhaust or oil cap or make any noises etcwhat you think?? Quote
N80Jamie Posted November 24, 2011 Posted November 24, 2011 Is the rocker cover pressurised? You should try it again but take it off before you start the car. Only reason i say that is because you can't remove the rad cap when the engine is up to temp but you can remove it before hand and get it up to temp (usually to clear any air in the rad). Oil cap could be the same? Quote
_shaun_ Posted November 24, 2011 Posted November 24, 2011 i was always under the impression if u took the cap off when it was running it was bound to split oil at u and that was just normal but i could be mistaken a compresstion test is the real test tbh Quote
Russleh Posted November 24, 2011 Posted November 24, 2011 its usually really bad when your rings are gone or piston ringland. i had mine off for about 1 second when mine was gone and it covered the wing and my tshirt in oil spatters. compared to having next to nothing on my hand when i rebuilt it and done the same. its the excess blowby. id do a comp test tho Quote
lew777 Posted November 24, 2011 Posted November 24, 2011 see mine wasnt spitting oil out just puffing air Quote
iamlegend Posted November 24, 2011 Author Posted November 24, 2011 ahh rest at ease haha!! I thought for the worsemate says "crankcase pressure also oil flying out is camshafts flinging about thats fine!hopfully Quote
Starlet__SR Posted November 24, 2011 Posted November 24, 2011 Don't worry about it. Getting worked up over nothingD Quote
