i have a front mount intercooler with the oem wastegate and efi pipe still attached. at the end of the efi pipe is a hks mushroom filter. thats it so will i get boost creep if i increase boost to .8 bar
yeah manz boost creep kills ye, try running super max boosts like 0.85 barz and be rapidz but if you hit FC like real bad back it off ye. trial and errorz
Ha har I love it !
Back to da question...
I'm running just under 12psi with part of the intake still on, down pipe, flowed manifold and my waste gate ported. I have had no problem's boosting yet even on the coldest days.
Hope this helps isn't it blood
x2
x3 Wish people wouldnt give shit advice! no wonder theres so many engines blowing :/
Just run 0.7 bar until you can afford a way of controlling boost better.
I ran 1bar with Frp and FCD for well over a year with no problems, had properly set up or a rolling road and never worried about it and was checked after 6months with no worries
It's your choice what you do, I removed the FCD when I upgraded the turbo tho
Yeah yeah you can run them safely on a good engine and set up properly but it isnt the best way of doing things. Go externally gated its the way forward!
FCD justs removes fuel cut and puts more stress on the engine which obviously isnt a good thing.
