micky boy Posted March 27, 2012 Author Share Posted March 27, 2012 Yeah thats what i wasnt to sure about!.im getting CRN brakes to do my disks so wonder if they could point me in the right direction. cheers for the link they do look like the ones also says they are for a 277mm disc so they have to be them because the twin pots use a smaller pad i (think?) Quote Link to post Share on other sites
Amjad Posted March 28, 2012 Share Posted March 28, 2012 Yeah twins are smaller than that so should be fine Quote Link to post Share on other sites
micky boy Posted March 29, 2012 Author Share Posted March 29, 2012 Thanks for your help again Amjad Quote Link to post Share on other sites
Keri-WMS Posted May 29, 2012 Share Posted May 29, 2012 I've been looking at this and I'm not sure the inside of the disc should need the 1.5mm taking off it! In fact my maths says it shouldn't. (I've got ST185 hubs, ST185 discs, and EP91 hubs etc here).Has anyone got a Starlet hub, STANDARD 280mm Astra disc and ST85 carrier (no pads) they can bolt up and photograph if the disc is centred in the carrier or not?I can probably supply pre-modified, 55.1bore (or 54.1mm to fit EP82 bore) 277mm Astra discs if people are interested. The locating rings will be permanantly fitted to the discs, not loose. Quote Link to post Share on other sites
Amjad Posted May 29, 2012 Share Posted May 29, 2012 If you were to supply those discs permanently I'd definitely know where to go when it comes to changing mine Quote Link to post Share on other sites
Keri-WMS Posted May 29, 2012 Share Posted May 29, 2012 Partly depends on demand! Quote Link to post Share on other sites
xx YICK xx Posted June 29, 2012 Share Posted June 29, 2012 Before and after machining, All bolted up tight Quote Link to post Share on other sites
Amjad Posted June 29, 2012 Share Posted June 29, 2012 ^Dude I can't remember whether I messaged you after I did the conversion but thanks again for your help! (& GTNomez if you're reading this!) Quote Link to post Share on other sites
xx YICK xx Posted June 29, 2012 Share Posted June 29, 2012 ^Dude I can't remember whether I messaged you after I did the conversion but thanks again for your help! (& GTNomez if you're reading this!)Your welcome mate, Bet your glad u did it, Best mod i done Quote Link to post Share on other sites
Amjad Posted June 29, 2012 Share Posted June 29, 2012 You already know, loved it on track one of the best mods so far Quote Link to post Share on other sites
5e colin Posted September 14, 2013 Share Posted September 14, 2013 do them astra 280mm disks work with the levin bzr twins and calipers just cut down to 260mm in diameter ??? Quote Link to post Share on other sites
Amjad Posted September 16, 2013 Share Posted September 16, 2013 No idea. ro55ifumi, ryan lang and shorty run twinpots I believe so they would be the people to ask Quote Link to post Share on other sites
shorty Posted September 16, 2013 Share Posted September 16, 2013 I run outlaw 2000 4pots now dude. But in theroy yea it would work. Thier is another astra disc that is smaller in diamiter that works better for levin twinpots. Have a lil search of the older tech posts. Me and turbo grant have posted the details a good few times as tbh i cant remeber of the top of my head. As its been a long while since I've touched twin pots now damn good breaks though! Loved mine tbf. Quote Link to post Share on other sites
Keri-WMS Posted November 8, 2013 Share Posted November 8, 2013 Before and after machining, All bolted up tight Just looking at this again - the lower photo is before machining 1.5mm off the inside of the astra disc bell, and the top photo is after? Quote Link to post Share on other sites
Amjad Posted November 8, 2013 Share Posted November 8, 2013 ^I think so Quote Link to post Share on other sites
akaye4000 Posted December 6, 2013 Share Posted December 6, 2013 you dont machine 1.5mm off the inside just turn down the outside and make a hub ring Quote Link to post Share on other sites
Amjad Posted December 7, 2013 Share Posted December 7, 2013 ^Not sure what you mean by that Quote Link to post Share on other sites
akaye4000 Posted December 7, 2013 Share Posted December 7, 2013 dont machine 1.5mm off the inside of the astra disc bell, just get a machine shop to turn the disc down to 277mm from 280 and make a ring to fit in the hub to make it fit a starlet properly Quote Link to post Share on other sites
Amjad Posted June 6, 2014 Share Posted June 6, 2014 dont machine 1.5mm off the inside of the astra disc bell, just get a machine shop to turn the disc down to 277mm from 280 and make a ring to fit in the hub to make it fit a starlet properlyForgot to reply to this, my bad! I spoke to two people including Yick who posted above, that are running this setup before I went ahead and got my kit. They both said to take 1.5mm off the back of the disc so it sits centrally in the caliper. Whether that is necessary I don't know, but the brakes have been fine for me in 2 years Road use and two track days. Quote Link to post Share on other sites
Jim* Posted June 7, 2014 Share Posted June 7, 2014 Great thread seems a cheap option for people Quote Link to post Share on other sites
5e colin Posted June 7, 2014 Share Posted June 7, 2014 well lads i did my levin twinpot setup with these disks apec DSK 2188 http://www.apecbraking.co.uk/catalogue/frictionview/item/736306 got them turned down to 260mm and 1.5mm of the inside face of the disk ( 4x100) and ordered plastik spigot rings of egay to fill the gap no longer studs or spacers kneaded they fit under my 14" enkei !!!! after i rounded the outside of the caliper a bit to clear the spokes Quote Link to post Share on other sites
Amjad Posted June 7, 2014 Share Posted June 7, 2014 Also I can't remember whether I've mentioned it, but it's worth pointing out that the ST165/early ST185s had Twin pots and 260mm discs. But it's the late spec ST185 that had the single pot 277mm discs. Quote Link to post Share on other sites
akaye4000 Posted June 8, 2014 Share Posted June 8, 2014 (edited) i run st202 brakes so maybe different again then Edited June 8, 2014 by akaye4000 Quote Link to post Share on other sites
K2NXY Posted October 14, 2014 Share Posted October 14, 2014 Hi guys just a quick question.. Did you have to get your discs balanced after they were machinined ? Cheers Quote Link to post Share on other sites
