scoobykilla Posted February 2, 2012 Share Posted February 2, 2012 Hi folks got my V back on the road today its got the belowToyosports mani and decatBlitz Nur Spec R full systemRX-7 top mountI know it wont be much more than standard power, but what BHP do you think i would be running ?? Quote Link to post Share on other sites
TrisK Posted February 2, 2012 Share Posted February 2, 2012 what boost are you running?standard airfilter/intake/pipe route? Quote Link to post Share on other sites
scoobykilla Posted February 2, 2012 Author Share Posted February 2, 2012 Standard boost as far as i know, HKS mushroom filter in standard place (up at back of engine bay) Quote Link to post Share on other sites
lew777 Posted February 2, 2012 Share Posted February 2, 2012 put it on the dyno Quote Link to post Share on other sites
madmax_926 Posted February 2, 2012 Share Posted February 2, 2012 150bhp ? Quote Link to post Share on other sites
mattyD Posted February 2, 2012 Share Posted February 2, 2012 around 140 i reckon but as said put it on a dyno Quote Link to post Share on other sites
Taggy Posted February 2, 2012 Share Posted February 2, 2012 go get your self an uprated fuel pump, Fuel cut defender, fuel pressure regulator and an adjustable actuator and you could be running up near 185hp for 1.0bar of boost on the standard turbo, the difference is immense even on the stock turbo.I reckon if you bought the bits used on here you could get a fuel pump for £50, fuel cut defender, £40, fuel pressure regulator about £60, actuator, £30-50, dyno to setup the fueling £40Would make your car seriously quick!!! Quote Link to post Share on other sites
scoobykilla Posted February 3, 2012 Author Share Posted February 3, 2012 Taggy sounds like a plan. Couple questions tho, i have a problem with the wheels spinning a lot in first second and 3rd gear, if i increase the power to say about the 180 to 190BHP whats the best way to stop this (i dont have that heavy a right foot either lol).Plus i kinda wanted to keep it below 1.0bar or is it safe enough running at 1.0bar as i use the car as my daily car ?? Quote Link to post Share on other sites
WallaceGlanza Posted February 3, 2012 Share Posted February 3, 2012 Taggy sounds like a plan. Couple questions tho, i have a problem with the wheels spinning a lot in first second and 3rd gear, if i increase the power to say about the 180 to 190BHP whats the best way to stop this (i dont have that heavy a right foot either lol).Plus i kinda wanted to keep it below 1.0bar or is it safe enough running at 1.0bar as i use the car as my daily car ??Better tyres and good throttle control, but at this time of the year there is no grip on the roads anyway. I've been runnning 1 bar for 4 years maybe so yeah it's fine -aslong as it's setup properly. Quote Link to post Share on other sites
templar2007 Posted February 3, 2012 Share Posted February 3, 2012 http://www.ukstarletclub.com/forums/index.php?showtopic=49715&hl=&fromsearch=1That's for wot brakes mate for about 200 so will be fine for about 180 Quote Link to post Share on other sites
mattyD Posted February 3, 2012 Share Posted February 3, 2012 if your worried about running 1 bar all the time, invest in an electronic boost controller that way you can run low boost when driving to work etc and high booost when you wna have a bit of fun but again only do this when all the other bits have been setup Quote Link to post Share on other sites
