akyakapotter Posted March 7, 2012 Posted March 7, 2012 ok so while doing my rear arb i noticed that my rubber bushes are split whreres the best place to get new ones and are there polybush ones ?? thanks nick Quote
akyakapotter Posted March 7, 2012 Author Posted March 7, 2012 (edited) would these do the trick ? CLICKY Edited March 7, 2012 by akyakapotter Quote
WallaceGlanza Posted March 7, 2012 Posted March 7, 2012 There's a few guys on here with them on a glanza but they're not necesarily quite a perfect fit. Have a search on here and you should find some info... Quote
rob_bower Posted March 7, 2012 Posted March 7, 2012 Try here ;)/>http://www.part-box.com/product_info.php?products_id=70379 Quote
Guard1an Posted March 8, 2012 Posted March 8, 2012 http://www.ukstarletclub.com/forums/index.php?showtopic=49151/>http://board.tercelonline.com/viewthread.php?tid=39844Not a perfect fit to EP91 beam, they are designed for EP82 beam.Check the second link to see the differences between two beams. Quote
JackStar Posted March 8, 2012 Posted March 8, 2012 you will need to weld a ring on each side to hold the bush, as when you take the glanza bush out theres only about 10mm to hold the bush, hope that make sense. Quote
SiCaln Posted March 8, 2012 Posted March 8, 2012 I have the 82 bushes shown, wonder if the ring around the bush could have the poly bush cut down and pushed in to it?! Quote
akyakapotter Posted March 8, 2012 Author Posted March 8, 2012 Looks like I'll replace with standard to much trouble for me to weld things in lol Quote
