Starbuck Posted March 26, 2012 Posted March 26, 2012 Fitted a new cover last night, so obviously leads off etc. Car idled fine this morning whilst putting why work stuffs in, fine down the motorway, in a queue etc. Pulled into works entrance and the car cut out. So started again and cut out once more. Managed to get it to hold rpm for a bit and got to the office where in the car park it held rpm for a bit but then dropped to 400 back up then stalled completely...So I'm stumped at the moment as to what's gone all of a sudden. As Sat was issue free it must be something I've done last night?? Quote
Idrees Posted March 26, 2012 Posted March 26, 2012 Did you put the PCV pipe back on properly? Did you remove any earths that you might have forgot to refit? Did you adjust the timing by any chance? Quote
Starbuck Posted March 26, 2012 Author Posted March 26, 2012 Sorry Rocker Cover...No timing messed with, no earths fiddled with.No longer has PCv valve. Runs a catch can setup. Just been out to car put some new leads on it and the car idled fine with no cutting out for a few minutes before turning off. Don't think it was the leads though..... It just decided to cause probs when I turned quickly into works entrance..... Quote
Starbuck Posted March 26, 2012 Author Posted March 26, 2012 I'll see tonight on my way home if after the car has warmed up it still does it. Quote
micky boy Posted March 26, 2012 Posted March 26, 2012 If your leads havent been moved about for some time they become very brittle due to heat and if you've took the rocker cover off you my of finished them off..But in the mean time make sure all the leads are cliped on right on the dizzy and plugs ect Quote
Starbuck Posted March 26, 2012 Author Posted March 26, 2012 Well they were old school oem ones..... So maybe. I'll see later when I've driven home what the car wants to do. :/ Quote
Josh@TunerLifestyle Posted March 26, 2012 Posted March 26, 2012 blocked off the port on the inlet mani ? Quote
Starbuck Posted March 26, 2012 Author Posted March 26, 2012 Thanks Josh but thats been blocked up ages. Quote
Josh@TunerLifestyle Posted March 26, 2012 Posted March 26, 2012 ahh ! only said because i forgot to cover mine up when i put mine on and it spluttered and stalled lol Quote
Socks Posted March 26, 2012 Posted March 26, 2012 marc!as mickey boy said... the ht leads can somtimes be quite stuburn to get off and pulling on them may have weaked them somwhere. There is now excuse for not having magnecores Both breather lines go to a catch tank, which canthen breathe to atomsphere yes? Quote
Starbuck Posted March 26, 2012 Author Posted March 26, 2012 Yes.Plus I've just put on today cjs 10mm leads on. Quote
Starbuck Posted March 26, 2012 Author Posted March 26, 2012 Took her for a little run around the camp. Didn't cut out but dropped revs a little when at idle or slowing..hmmmm Quote
micky boy Posted March 26, 2012 Posted March 26, 2012 Whats your plugs like? sounds like they are getting flooded with fuel on idle and arnt sparking to there full potential! Quote
Starbuck Posted March 26, 2012 Author Posted March 26, 2012 Why would that start all of a sudden.....? Bloody engines. I did notice white smoke from the catch can, but I guess that's just condensation from the hot vapours Quote
Nads Posted March 26, 2012 Posted March 26, 2012 Not saying your rings are going, but this is what happened to my gt.White smoke from the Catch can and low revs and stalling Hope it's not tho mate! Quote
micky boy Posted March 26, 2012 Posted March 26, 2012 Thats engines for you lol i change my plugs the other month had them in for about 15miles and they killed my leads!. Must of been that bit more surge going through the leads that finished them off!..On a side note i hope it isnt your rings! do a compression test to be sure Quote
DavidAshton Posted March 26, 2012 Posted March 26, 2012 Yes.Plus I've just put on today cjs 10mm leads on.You put new ignition leads on and the engine starts stalling.I think you have ansered your own question! Quote
Flaminsam Posted March 26, 2012 Posted March 26, 2012 Just a thought but with the engine running and it stalling after some time, could you have too much crankcase compression? When it cuts out next time, pull the dipstick out and listen for air coming out. Quote
Starbuck Posted March 26, 2012 Author Posted March 26, 2012 You put new ignition leads on and the engine starts stalling.I think you have ansered your own question!I put new leads on after the issues but it hasn't seem to cure it. So doubt its them. Quote
Starbuck Posted March 26, 2012 Author Posted March 26, 2012 Just a thought but with the engine running and it stalling after some time, could you have too much crankcase compression? When it cuts out next time, pull the dipstick out and listen for air coming out.Thing is the race SPEC is less restrictive than the previous catch can setup. So I doubt its that either.... Quote
Starbuck Posted March 26, 2012 Author Posted March 26, 2012 Drove it home fine to a degree. However it looks like when the engine hits warm the probs start. Stalling started again when slowing down. Oil temp hit 110ish on normal mway driving. Car seemed like it lacked power, engine seemed to make a very slight drumming sound, only slight and not constantly.Water temp stayed quite normal Gonna comp test it, check fluids etcMaybe the trip to Dave B meet might have helped the engine in its way...... Quote
J25GTi Posted March 26, 2012 Posted March 26, 2012 wouldnt a cts problem cause issues when running from cold/ up to temp? Quote
