theminiguru Posted June 2, 2012 Posted June 2, 2012 Replacing my standard steering wheel with a boss kit etc. I've heared you can confuse the car in thinking the airbag is still attached by doing something with the wires that plug into it? Does anyone know how this is done? Will be massively appreciated Quote
akyakapotter Posted June 2, 2012 Posted June 2, 2012 surely its just a case of bridging the connection so it thinks its still there. Sure some one will no the correct answer Quote
daniel_g Posted June 2, 2012 Posted June 2, 2012 You just need a resistor, not sure what ohms though. Get a few and try them. Quote
jamesglanza Posted June 3, 2012 Posted June 3, 2012 I used this bosshttp://www.ebay.co.uk/itm/STEERING-WHEEL-HUB-BOSS-KIT-Toyota-STARLET-inc-GLanza-/360428659497?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item53eb38e329Plugged in the wires and no light came on the dash so happy days. Dont forget to disconnect the battery lolThink it has to be (Part No. T-16) as this is the one for air bags and has the resistor to plug the wires into so the light on the dash stays off. Quote
