Tracking is all normal on my Meisters with max +ive camber (Whiteline ALK)
Camber is set to -1.2 on front and I have -0.5ish on the rear
Rears fixed unless you shim it,
Tbh it depends on how hard your guna set them, the harder they are the less likely you are going to roll so having max camber would be pointless as the car would struggle to roll onto yhe flat of the tyre, unless you have very sticky tyres and a good road surface or are a nutter lol
My bc's are at either -1 or - 1.2 and midway on damper setting toe/tracking is 0.
I have alk and polybushed stock arb aswel
One day im going to get my car set up for track in which case these will no doubt change to a more aggressive setting
-2 in camber, 3 in caster, -1.5 in tracking.
White line specs:
1 camber for road
1-2 for fast road
2-3 for tracks
Max caster using caster kit/anti lift kit
Tracking -1
might aswell throw my settings in
-1 camber
max + caster which i think is 2.5 with white line alk
0 toe
cheers guys ob as i said i have bc coilovers and atm not got a anti lift kit but it on my to buy list
anyone fancy giving me a list of what to buy for the rest of suspension i have a adjustable para rod and that it for now i no i need a rear arb and poss a upgraded f arb so what else do i need :p cheers guy i only asking because atm i got some much going on with the engine and turbo build i kinder forgot about the rest of the suspension
Well the only bushes left to do after f arb is the front wishbone bush and rear axle bush on both sides then upper lower front strutbraces, rear upper n thats about it other than tyres and brakes.
I got upper strut brace and rear brace I need a place to find a lower strut also u recomend anywhere I could get it all from ?
