jellybaby Posted June 12, 2012 Share Posted June 12, 2012 Hello people I have by coil overs and want to set the tracking and camber but what do most people run On camber and tracking ? Quote Link to post Share on other sites
Jamie1st Posted June 13, 2012 Share Posted June 13, 2012 My camber is set to -1.4 deg, can't remember about tracking. Quote Link to post Share on other sites
Amjad Posted June 13, 2012 Share Posted June 13, 2012 Tracking is all normal on my Meisters with max +ive camber (Whiteline ALK)Camber is set to -1.2 on front and I have -0.5ish on the rear Quote Link to post Share on other sites
morgey Posted June 13, 2012 Share Posted June 13, 2012 Rears fixed unless you shim it,Tbh it depends on how hard your guna set them, the harder they are the less likely you are going to roll so having max camber would be pointless as the car would struggle to roll onto yhe flat of the tyre, unless you have very sticky tyres and a good road surface or are a nutter lolMy bc's are at either -1 or - 1.2 and midway on damper setting toe/tracking is 0.I have alk and polybushed stock arb aswel One day im going to get my car set up for track in which case these will no doubt change to a more aggressive setting Quote Link to post Share on other sites
klyfax Posted June 13, 2012 Share Posted June 13, 2012 -2 in camber, 3 in caster, -1.5 in tracking.White line specs:1 camber for road1-2 for fast road2-3 for tracksMax caster using caster kit/anti lift kitTracking -1 Quote Link to post Share on other sites
jellybaby Posted June 13, 2012 Author Share Posted June 13, 2012 Cheers guys Quote Link to post Share on other sites
Liam_D Posted June 13, 2012 Share Posted June 13, 2012 I run and always recommend -1.5 and toe set to neutral! Quote Link to post Share on other sites
Asad Posted June 13, 2012 Share Posted June 13, 2012 might aswell throw my settings in-1 cambermax + caster which i think is 2.5 with white line alk0 toe Quote Link to post Share on other sites
jellybaby Posted June 13, 2012 Author Share Posted June 13, 2012 cheers guys ob as i said i have bc coilovers and atm not got a anti lift kit but it on my to buy listanyone fancy giving me a list of what to buy for the rest of suspension i have a adjustable para rod and that it for now i no i need a rear arb and poss a upgraded f arb so what else do i need cheers guy i only asking because atm i got some much going on with the engine and turbo build i kinder forgot about the rest of the suspension Quote Link to post Share on other sites
morgey Posted June 13, 2012 Share Posted June 13, 2012 Well the only bushes left to do after f arb is the front wishbone bush and rear axle bush on both sides then upper lower front strutbraces, rear upper n thats about it other than tyres and brakes. Quote Link to post Share on other sites
jellybaby Posted June 13, 2012 Author Share Posted June 13, 2012 Well the only bushes left to do after f arb is the front wishbone bush and rear axle bush on both sides then upper lower front strutbraces, rear upper n thats about it other than tyres and brakes.I got upper strut brace and rear brace I need a place to find a lower strut also u recomend anywhere I could get it all from ? Quote Link to post Share on other sites
Jamie1st Posted June 13, 2012 Share Posted June 13, 2012 I've got a front lower brace is sell, brand new. pm me Quote Link to post Share on other sites
jellybaby Posted June 13, 2012 Author Share Posted June 13, 2012 I've got a front lower brace is sell, brand new. pm mepic? Quote Link to post Share on other sites
Jamie1st Posted June 13, 2012 Share Posted June 13, 2012 PM.d dude Quote Link to post Share on other sites
