Ive done it to my m8s ford escort and we had to depreassurise the fuel system and we did this by taking out a fuse then startin the car up until it died due to no fuel pressure, But i dont know which fuse it is in the starlet na. Can anyone help? Thanks very much
Ryan
Dont really need to do that, you can take the cap off the fuel flap, dunno if that makes a diffrence though :D Its only a wee bit of fuel that pisses out anyway :)
Ok thanks will give it ago and report bk
Ryan
  • 1 year later...
Digging up old threads here, but just want to double check before I go spraying petrol everywhere -
Is it ok to just do the "take the filler cap off" method? Or do you need to take the fuse out and get it out of the system?
bud i think that there meaning that when you take the fillet cap off it lets a bit of preacher out of the system, or thy mean just take the top connector off the filter
Never done a fuel filter on the EP..did it on a 306 TD and done it on the Jag loads of times..never needed to do anything other than whip off cover to filter, remove filter, replace filter...bolt up and drive.
That's what I thought, just wanted to make sure. Thanks
Taking the fuel cap off will just release the pressure in the fuel system so it doesnt spray out when you undo the first bolt, instead with the cap undone it will just be a pathetic dribble like an 86 year old man at the urinal.;)
Taking the fuel cap off will just release the pressure in the fuel system so it doesnt spray out when you undo the first bolt, instead with the cap undone it will just be a pathetic dribble like an 86 year old man at the urinal. :p
Nice precise description there.
