help with leds?? dash bulbs?
Hi guys.
I need someone who knows about LEDs
I know nothing about leds. so I would need some help.
I want to replace some of the dash bulbs on my dash to LEDs. At the moment I see little light bilbs with a green nipples on it.
I want to replace them with a White LED but I am unsure which ones I need.
However I have managed to find a little info but I am still unsure which ones I need.
(reading from japan auction) they are saying something about T3-1 and T4.2 do these sound right?
Any good place to buy these from? found 1 on ebay from ireland but seems to be quite expensive.....unless thats the going rate?
Thanks
  On 7/7/2012 at 10:20 AM, glanzav98 said:
Take out a bulb and measure the base of it then look at the sizes below to see what you need. Then go to this link: http://www.ebay.co.u...bulbs&_osacat=0
  • T3 - 8mm Base diameter
  • T4 - 10mm Base diameter
  • T5 - 12mm Base diameter
:thumbsup: ah man, you're a star. Just bought some of those bad boys. Thank you so much
  • 6 months later...
Did this a year ago so I'm not quite sure but 2xT10 and 4xT5 IIRC. Buy a few extras and you won't miss one. Also remember to check the + and - :-)
Edit: Glanza cluster from back, thanks to austarletclub
Edited by JayJ
