What could cause bad MPG
I've only been getting 30mpg max , thats running in aswell! everything is standard
what mgp should i be seeing roughly when not driving hard?
Lambda ?
water temp sensor to ecu?
air charge temp?
Help guys :)
Thanks Dave
short journeys? starlet over fuel standard and doin lots of short journey means that it will return low MPG.
also driving style, have a look at you boost gauge. if you cruising around and have it on 0 boost you got a heavy foot. the gauge will tell you how hard your accelerating.
Edited by 5T4R7ET N/A
