Ryan5793 Posted July 28, 2012 Posted July 28, 2012 Do the glanza front wishbones, suspension, hubs ect fit a uk sr? I'm guessing they will? Basically I wanna drop everything from my glanza onto the sr so I can get it all refurbed and ready for the turbo conversion at a later date. Any help would be much appreciated. Ta Quote
micky boy Posted July 28, 2012 Posted July 28, 2012 (edited) Yep they are the same mate think the front arb/drop links are different on the SR but the glanza one will just bolt stright on in place of it Edited July 28, 2012 by micky boy Quote
ryan lang Posted July 28, 2012 Posted July 28, 2012 i think the hubs are different because of the abs arent they?or do the SR's have abs too? Quote
micky boy Posted July 28, 2012 Posted July 28, 2012 (edited) Yeah they different but he's asking if the glanza Hubs will bolt onto the SR front wishbones ect and they will as for as im awareGlanza wishbones are the same as the SRSR hubs are different because of the ABS and think they have a less splin count then the glanza hubs but not a 100% suresuspensions the same ect Edited July 28, 2012 by micky boy Quote
Starlet__SR Posted July 28, 2012 Posted July 28, 2012 I think the bottom arm bushes are a different size. The hub units can be swapped over as the ABS uses a pick up ring on the CVDay Quote
Ryan5793 Posted July 28, 2012 Author Posted July 28, 2012 Thanks guys, like I say I just wanna swap the whole front end set up so I can get bits power coated and polybushed, I've got a whiteline front anti roll bar to go on too Quote
zebedee Posted August 26, 2012 Posted August 26, 2012 Does a glanza s have abs then??Most do yes Quote
Dickydan Posted August 27, 2012 Posted August 27, 2012 Ok thanks wasnt too sure on the glanza s lol one last question does the glanza s share the same looms as the glanza v? Quote
Dan507 Posted August 27, 2012 Posted August 27, 2012 Does a glanza s have abs then??Yes, i can confirm this. I also have an ABS sticker on the rear window. Ok thanks wasnt too sure on the glanza s lol one last question does the glanza s share the same looms as the glanza v?Don't think so. it should be the same as a uk spec N/A Quote
zebedee Posted August 27, 2012 Posted August 27, 2012 The loom will be a mix of the two as you will not have all the sensors for the turbo but the looms will have ABS and air con on unlike the UK sr Quote
Dickydan Posted August 28, 2012 Posted August 28, 2012 So ifni tirbo convert an s id still need the engine and dash loom?? If i turbo*** Quote
