  • Replies 199
  • Created
  • Last Reply
Top Posters In This Topic
parts are beginning to mount up now got a
1. cap clutch
2.notched bottom end
3.scat Forged conrods
4.acl main big end thrust bearings
5 Oem rear splitter
6. Livesports Front Bumper
Edited by russ78
parts are still stacking up, :D
got my new turbo today my plan is to run this CT9/CT12 Hybrid at 1.4 bar no ideas about the results though
also got a civic rad
Edited by russ78
hybrid at that boost will be running very hot and blowing out hot air mate! mine at 1.2 bar was at that and had to sacrifice some top end power with the map
Edited by starletburkie
can i ask was it a ct12 hybrid or ct9 as my old ct9 hybrid ran fine at 1.2bar but this has a much larger compressor wheel etc etc as it uses ct12 housing
tongs spec gt hybrid mate! its all down to the stock restrictive exhaust housing imo. my one ran good at 1.0 bar and at 1.2 bar it made very nice toque however it had alot of detonation above 5500rpm in 5th so had to loose alot of power to have it safe
  • 2 weeks later...
not updated for a little while so here goes finally ordered my remaining parts from Idworkz so in the post is
1.2 Athena Headgasket
74.5 Wossner Pistons
and ARP headbolts :)
cheers again iddy
Also dropped into the machine shop and they reckon 1 week to machine the block to my specs
engine stand turned up as well
gotta order engine gasket set but no urgency for that till blocks been to the machine shop
finally some progress
Edited by russ78
