scoobykilla Posted September 7, 2012 Posted September 7, 2012 Thinking about putting powerflex engine mounts on the V, is this a reasonably easy job? Any guides aor how to's? Quote
B11G KY Posted September 7, 2012 Posted September 7, 2012 (edited) Its not to hard pal same as everything it depends on how competent you are,1) Slightly loosen all engine mounts while its grounded (to stop car rocking in step 4)2) Get the front up on axle stands3) use jack to hold up engine4) finish undoing the first engine mount5) replace rubber with poly and reassembleRepeat steps 3-5 on the restto get the rubber out people use all different methods some burn/melt it out and some us a drill and a hack sawGood LuckKy Edited September 7, 2012 by B11G KY Quote
Johnboy GT Posted September 7, 2012 Posted September 7, 2012 If you need a hand Jamie I can help. Ive done mine, granted engine was out but it wasn't my first time ;). John Quote
scoobykilla Posted September 7, 2012 Author Posted September 7, 2012 Haha cheers lads al give it a go, am pritty competent but we will soon see, cheers John al gee y a shout if i struggle. got a clutch t change soon aswell so will be busy busy lol Quote
StuDoc 72 Posted September 7, 2012 Posted September 7, 2012 If you have a vice to do your bushs then youl be fine. Quote
rorenapier Posted September 7, 2012 Posted September 7, 2012 Do your bushes at the same time as the clutch? Make life easy..A vice to put the bushes in? Why? Powerflex will go in with your hands. Quote
corofin12345 Posted September 7, 2012 Posted September 7, 2012 (edited) remember, after getting out the rubber, ull have to take out the rings also or the powerflex rubbers wont fit in.. after that its simple... each mount rubber comes in 2 halfs so slots in either side of mount, then just insert pin...i just cut out both engine mount rubbers with a hacksaw blade but had to burn out the gearbox mount rubber.. to cut out the rings, just cut through in 2 places and they will fall out Edited September 7, 2012 by corofin12345 Quote
StuDoc 72 Posted September 7, 2012 Posted September 7, 2012 (edited) A vice to clamp the arm in when your removing them??? Always makes life easier do you not agree? Edited September 7, 2012 by StuDoc 72 Quote
shorty Posted September 7, 2012 Posted September 7, 2012 Have to say is a damn sight easier to saw the old collars out when the mount is held in a vice but can still be done without one tbh. Quote
Johnboy GT Posted September 7, 2012 Posted September 7, 2012 I did two of them in a vice and the back gearbox on the car. I mite be rough but i sawed so much then used a hammer and chisel to knock it out!John Quote
corofin12345 Posted September 7, 2012 Posted September 7, 2012 just do one at the time. that way it will be easier re locating them in the bay without jacking pulling and dragging Quote
StuDoc 72 Posted September 7, 2012 Posted September 7, 2012 Have to say is a damn sight easier to saw the old collars out when the mount is held in a vice but can still be done without one tbh.I did two of them in a vice and the back gearbox on the car. I mite be rough but i sawed so much then used a hammer and chisel to knock it out!JohnCheers guys. Quote
Starlet__SR Posted September 7, 2012 Posted September 7, 2012 Or just use a bush removal tool?Day Quote
