daniel_g Posted October 13, 2012 Posted October 13, 2012 Ok so i have removed the dashboard from the gt and want to take away some of the shizz from behind it.What is safe/ok to remove? Quote
Glanza Mac Posted October 13, 2012 Posted October 13, 2012 +1, ive just removed my dash in my glanza Quote
jellybaby Posted October 13, 2012 Posted October 13, 2012 (edited) Well if u got air con u can remove the silly big black box connected to ya blower and remove the cooler inside it so u have no pipes coming through the bulk head also weights a ton Edited October 13, 2012 by jellybaby Quote
Beastmode panda Posted October 13, 2012 Posted October 13, 2012 and sound deadening.by the way how easy/long did it take to remove the dash? i want to take out the aircon unit from under there which weighs a ton like said above! Quote
daniel_g Posted October 13, 2012 Author Posted October 13, 2012 It took roughly an hour maybe a bit more to take the dash out. But that was with the steering wheel, glovebox, stereo etc already out. On a gt.The ac had already been taken out by someone else. I took the blower unit out, might just leave it out tbh. Took the tunnels for the hot air out aswell. Quote
Beastmode panda Posted October 13, 2012 Posted October 13, 2012 Sheesh, might give it a miss then lool. Quote
danb87 Posted October 13, 2012 Posted October 13, 2012 I stripped the dash out includinf stereo /wheel etc ina bout 15 mins. Hardest bit is removing the tape etc that holds wires too dash. Dont recall seeing much behind worth removing but good too tidy things up. I positioned relays etc all in easy accesible areas. Aswel as running any gauge wires /emu loom tucked up an tidied. Looked very diffrent behind , an dash went back in so easily. Dan Quote
Beastmode panda Posted October 14, 2012 Posted October 14, 2012 can you not take the air con thing out if ypu just take the glove box out? Quote
daniel_g Posted October 14, 2012 Author Posted October 14, 2012 Yeah i think you can, deffo worth doing as there is a substantial amount of shit you dont really need behind there. Removed the heater matrix and housing too. Quote
StarletMad Posted October 14, 2012 Posted October 14, 2012 Yeah the f***ing white clip things that the looms tapes to are a pain in the arse. The bolt behind the clock had me in deep thought for quite a while Quote
daniel_g Posted October 14, 2012 Author Posted October 14, 2012 The 10mm behind the time clock got me haha Quote
StarletMad Posted October 20, 2012 Posted October 20, 2012 If removing the sircon part is it this white bit??Cheers Quote
jellybaby Posted October 20, 2012 Posted October 20, 2012 If removing the sircon part is it this white bit??CheersNo dude it the black box next to it Quote
