Looking over my engine bay today and I noticed what looks like a temperature which has an electrical spade connection on it which has nothing plugged into it. It's directly next to the top radiator hose going into engine. I'm just wondering why it's not plugged in I can't see any obvious reasons and no wire.
Thanks!
Temperature sensor*
Sorry I didn't make that too clear it's beneath the alternator and directly next to where the top rad hose comes into the engine.
Ahhh god I'm having one of those days it's beneath the distributor!
This is a single spade connection, looks like its in the cooling system, there is a grey plug on the loom which feeds most things on that area of the engine which I was thinking was possibly unplugged from the ac, I could be wrong.
Thanks
any pics of it i think your confused? the rad pipe and alternator are nowhere near one another buddy. Front or rear of the engine and is it the head of the engine rather than the block?
temp gauge sensor id say... its possible your running a 3 pin CTS on a 1996/1997 water housing... 1996/1997 water housing has a spade connection for the temp gauge where as the 1998/1999 water housing doesnt have this... its the 3rd pin in the CTS.. what year is your glanza, 96/97/98 or 99????
Edited by corofin12345
Can't upload pics I'm having to use my phone, I meant the dizzy cap not alternator if you follow the top rad hose to the engine it's the first sensor in. It is a 96 glanza, yeah I am slightly confused I'm trying to understand 4efte's again after owning a cupra. Thanks
aye mate its your coolant temp sensor there shud be a small plug comin off the loom im sue but iirc its pretty fragile wires some one else would have to confirm tho dont take this as gospel.
Yeah it looks like on there looks to be one on the thermostat housing which is why I'm confused i can't find the wire or plug for it in the loom I really can't find it very confused, hmmm!
ok, heres a 96/97 water housing, could you confirm which sensor your on about..
the sensor beside the red dot?
or the sensor beside the yellow dot?
I have red and yellow plugged in strangely the sensor in question in your picture is replaced with a bolt, just to the left of the yellow dot, big thanks for the picture.
That is the correct sensor, the Red one im not familiar with but may be tucked away I can double check, but the other one in place of where the bolt is in your picture is the same sensor as I am trying to describe! Thanks once again
it just could be an aftermarket temp gauge sensor mate.. i wouldnt worry about it....
Aha, bingo so long as I'm not missing something major, that's perfect, didn't think of that. Thanks for your help, much appreciated. What's the difference between the two housings you sent I.e. are they both 96 specs?
Thanks once again!
Thanks once again!
first picture is is 96/97 spec.. the 98/99 spec housing doest have the spade connection "red dot in first picture", instead theres a 3rd pin in the CTS sensor/loom for temp gauge, "yellow dot"... the last picture is from an automatic housing
