H_D Posted October 26, 2012 Share Posted October 26, 2012 My clutch seems to be slipping, It was fitted about 5000 miles ago.I have an oil leak from the crank seal on the gearbox side coud this be the reason why my clutch has started slipping Is it possible for oil to get on the clutch if the crank seal on the gearbox side is leaking? Quote Link to post Share on other sites
Socks Posted October 26, 2012 Share Posted October 26, 2012 Yes Absolutely!Oil is a lubricant, you dont want to lube a service that needs to grip!It will have contiminated the clutch plate now...So New Seal, De-Grease and new clutch im afraid! Quote Link to post Share on other sites
pick1 Posted October 26, 2012 Share Posted October 26, 2012 Agree with the above best thing to do Quote Link to post Share on other sites
H_D Posted October 26, 2012 Author Share Posted October 26, 2012 Yes Absolutely!Oil is a lubricant, you dont want to lube a service that needs to grip!It will have contiminated the clutch plate now...So New Seal, De-Grease and new clutch im afraid!Cheers mate,Just been quoted £62 for a 3 piece excedy clutch. I already got a crank seal lying around somwhere and some brake/clutch cleaner....can anyone guess what il be up to this weekend....lol Quote Link to post Share on other sites
StuDoc 72 Posted October 26, 2012 Share Posted October 26, 2012 £62 that cant be right Quote Link to post Share on other sites
morgey Posted October 26, 2012 Share Posted October 26, 2012 Stock replacement. Same clutch as my 4age was about the same price. Clutch plate, cover and bearing id asume. Quote Link to post Share on other sites
lukEp Posted October 26, 2012 Share Posted October 26, 2012 The oil leak needs to be really really bad from the crank seal clutch side to get to the clutch as it has a flywheel in the way, it's more likely the rocker gasket leaking on that side making its way through the gearbox and on to the clutch or the gearbox its self, unless the person who fitted your clutch took the flywheel off? and didnt reseal the bolts and it's coming through the tread or maybe your clutch pressure plate is just fubard, which does happen and it's just you crank seal is leaking at the Same time. Quote Link to post Share on other sites
H_D Posted October 26, 2012 Author Share Posted October 26, 2012 £62 that cant be rightThats trade price from my uncles garage 3 piece kit with bearing, friction plate and pressure plate Quote Link to post Share on other sites
H_D Posted October 26, 2012 Author Share Posted October 26, 2012 The oil leak needs to be really really bad from the crank seal clutch side to get to the clutch as it has a flywheel in the way, it's more likely the rocker gasket leaking on that side making its way through the gearbox and on to the clutch or the gearbox its self, unless the person who fitted your clutch took the flywheel off? and didnt reseal the bolts and it's coming through the tread or maybe your clutch pressure plate is just fubard, which does happen and it's just you crank seal is leaking at the Same time.Its definatly not the rocker cover gasket/dizzy or head related i had a proper look yesterdayThanx anyway Quote Link to post Share on other sites
H_D Posted October 26, 2012 Author Share Posted October 26, 2012 (edited) Could i get away with just changing the clutch plate and cleaning the rest? Edited October 26, 2012 by H_D Quote Link to post Share on other sites
StuDoc 72 Posted October 26, 2012 Share Posted October 26, 2012 (edited) Yes the only thing that will be knackered is thefriction plate which uses a similar material to brake pade which is absorbant. If you want to try and save more money when u take the friction plate out if the surface appears oily you can rub it down with a bit of emery paper and if the oilyness doesnt come back and it stays dry and dusty then its ok to use. Edited October 26, 2012 by StuDoc 72 Quote Link to post Share on other sites
Socks Posted October 26, 2012 Share Posted October 26, 2012 The Clutch disk is the bit with the friction material on it... Thats the bit that will get contiminated..Sure it isnt gearbox oil? Seal on box could casue this too... Quote Link to post Share on other sites
StuDoc 72 Posted October 26, 2012 Share Posted October 26, 2012 (edited) Should be able to tell by the smell of the oil if any has dripped out the bottom of the bell housing. If it smells of cat piss its gearbox oil lol. Edited October 26, 2012 by StuDoc 72 Quote Link to post Share on other sites
