Basically since fitting my whiteline RARB I've been getting knocking and creaking noises coming from it.
Now I've given it a jolly good yank and it seems solid as, im just wondering if its just that its 2nd hand and the bushes are dry (no i didnt have any grease at the time!) or if they're worn maybe?
Or even if I've drilled the drop link holes in the wrong place (no instructions) i mounted them vertically above the rear most part of the bar?
Anybody have the same/similar problems?
Thanks for any input in advance :)
Yes they knock like fuck when they dry out, it will be the main bushings on the rear axel that the bar goes through, they need plenty of grease.
I have to re apply 6 monthish to keep mine quiet!
also check the captive nuts are super tight they are renound for working loose. very common on the wl bars. search tgtt and it comes up loads :(
