grimr3ap3r_ Posted October 31, 2012 Posted October 31, 2012 Hi well got blitz ecu in now and my Wepr externally gated kit,All fine onlyProblem I have is when cold the car holds back for 1.5 - 2.5kIt doesn't seem to do this when warm, I'm gonna change the leads plugs and distributorWhat else could cause this invade there's something really simple I'm missing,Also the car hunts for the idle some times when I'm stopped in traffic never cuts out thoughThanks for your help in advance guysIncase Quote
funny onion Posted October 31, 2012 Posted October 31, 2012 I'd say its running lean. Get a wideband on it. Is the ecu mapped to your car? Quote
grimr3ap3r_ Posted October 31, 2012 Author Posted October 31, 2012 Nahh Kate it's plug and play, it's fine after 2.5 k and it sounds healthy it's just like there's no boost or spool and then it's thereIt's fine when warmThanks in advance mateMate* Quote
funny onion Posted October 31, 2012 Posted October 31, 2012 The only thing "plug and play" about an ecu is the ability to plug the standard looms straight into it really. I wouldn't dream of plugging an ecu In my car without knowing what map was on it. That's just me though. Mine used to suffer from this on an external wepr kit. It was hesitant at a certain point in the rev range and then it would start pulling. Had it at race tech and the problem was it was running drastically lean. New plugs/ignition overhaul, then if it continues to do it then get a wideband on it and check afr. Quote
micky boy Posted October 31, 2012 Posted October 31, 2012 (edited) Dont boost untill its warm I always warm my car up untill the choke comes off so i've never come across that problem lolAs for the idle hunting mine dose this every now and again and im also runnig a Blitz ecu! Not sure if its just the map on themHow bad is the hunting on tick over? mine just pulses up and down ever so slightly! every now and again Edited October 31, 2012 by micky boy Quote
grimr3ap3r_ Posted October 31, 2012 Author Posted October 31, 2012 The hunting isn't bad to be honest I can live with itI only boost when warm but like if it's not full temp seems to do itI'm gonna change what I said above and get the furling checked I got a rrfpr anyway so hopefully be an easy fix really want it sortedThanks for the heads up yall really appreciate it (y) Quote
funny onion Posted October 31, 2012 Posted October 31, 2012 Yeah it won't be anything massive, don't panic about it. Ignition overhaul and if it persists take it to a tuner like tuning developments or race tech or rdt and get someone to check it on the rollers. Your ignition timing may be slightly out or something daft Quote
grimr3ap3r_ Posted November 1, 2012 Author Posted November 1, 2012 Sound mate I'll let you know how I get on Quote
AdamB Posted November 1, 2012 Posted November 1, 2012 Coolant temp sensor can do this. Swap it for a known working one with someone close by or something mate Quote
funny onion Posted November 1, 2012 Posted November 1, 2012 Also clean air temp sensor on the inlet, can't hurt mine was covered in crap and it idled loads better after I cleaned it Quote
H_D Posted November 1, 2012 Posted November 1, 2012 very unusual if it runs lean.Plug and play ecus are ment to run a lil rich Quote
Amjad Posted November 1, 2012 Posted November 1, 2012 Did you let it idle for about 20mins when you first plugged it in? Quote
Starbo Moorley Posted November 1, 2012 Posted November 1, 2012 Sell it and buy emb problems solved Quote
corofin12345 Posted November 1, 2012 Posted November 1, 2012 doesnt sound like a ecu problem at all.. probably your ext/wastegate sticking when cold... as for the hunting.. all these plug and plays idle differently as ive found out.. each p&p ecu i put in my car i had to adjust to suit.. the jam ecu comes down the revs very fast after reving so if the ICV isnt clean it will hunt.. the blitz seems to be slower coming down the revs but it still has the same issue when trying to find the idle.. id clean the sensors mentioned above... CTS, ATS and clean the ICV when your at it... might be worth while cleaning the lambda too if you can get at it.. Quote
grimr3ap3r_ Posted November 1, 2012 Author Posted November 1, 2012 I left it running for Hal hour when i plugged it inIt's only when it's cold I'll clean the above mentioned, is te coolant temp sensor the one on front of the thermo?Just got a dizzy and rotor from Toyota and my plugs and leads should be here tomorrow off CamskillThanks for all the help guys Quote
grimr3ap3r_ Posted November 1, 2012 Author Posted November 1, 2012 The hunting is minor really I'm more concerned about the car holding back from 1.2 to just under 3k when cold then it smacks me in th face with boost and takes offIf the wastegate was sticking how can I check this or what would I have to do to rectify it? Quote
grimr3ap3r_ Posted November 1, 2012 Author Posted November 1, 2012 I'll get some pics up this weekend been o Uksc for years never done a build threadAgain thanks for all the help and possible solutions guys Quote
grimr3ap3r_ Posted November 1, 2012 Author Posted November 1, 2012 To be honest I anticipate it being the plugs leads or dizzy I had the car setup and running for 3 days fine, had it valated and that's when the problem started don't know of some waters got in somewhere or something but where the king lead plugs into the dizzy there is a lot of corrosion so worth changing anyway Quote
funny onion Posted November 1, 2012 Posted November 1, 2012 Be careful! Mine was exactly the same And when the king lead was pulled out the pin stuck in the dizzy and chewed it. New dizzy hahaha Quote
grimr3ap3r_ Posted November 1, 2012 Author Posted November 1, 2012 I got a new dizzy and rotora to goon broMay. As well just replace it Quote
grimr3ap3r_ Posted November 3, 2012 Author Posted November 3, 2012 Ok I changed the rotor dizzy plugs and leads took it for a spin and it drove minttttThen I took it out again and it done it gain!Fed up might just buy a low mileage engine (n) Quote
grimr3ap3r_ Posted November 3, 2012 Author Posted November 3, 2012 How much should I be paying to get the furling checked? Quote
