steve-gers Posted November 1, 2012 Posted November 1, 2012 Planning to convert my auto to a manual around x-mas/new year time so starting to collect parts now. I already have a good gearbox and an clutch capable of handling the TD04 plus some TRD mounts but I still require these parts:-Brake and clutch pedalMaster cylinderSlave cylinderLine between master & slaveGear linkagesFlywheel & boltsGearstick + assemblyIf anyone is breaking a car or has these parts lying about (preferably cheap as i'm on a budget ) I would be grateful if you could post on here or PM me. Thanks
Socks Posted November 2, 2012 Posted November 2, 2012 I have a gearstick assembly?PM me a price and ill ship u it out!
Idrees Posted November 7, 2012 Posted November 7, 2012 Brake and clutch pedalMaster cylinderSlave cylinderGear linkagesFlywheel & boltsGearstick + assemblyWe have this lot here in stock. I'll send a price over via PM mate. CheersIdreesID-Workz
steve-gers Posted November 21, 2012 Author Posted November 21, 2012 Here is the updated list of parts that I need for the conversion. If I have missed ANYTHING at all out that anyone can think of please let me know. ThanksGearbox Partsgearboxflywheelflywheel boltsrear engine mount bracket (gearbox side)rear engine mount (chassis side) and bolts to matchLH side engine mountLH side engine mount bracketmanual gearbox bell housing boltsmanual starter motormanual starter motor boltsClutch Partsclutch kit (clutch plate, pressure plate and thrust bearing)if installing a new clutch kit (this is recommended) get the flywheel machined.clutch pressure plate boltsclutch release forkclutch release fork bootclutch slave cylinderclutch slave cylinder boltsclutch master cylinderhydraulic clutch lines short and long steel lines and the rubber linehydraulic clutch line brackets and clipsclutch pedal bracketclutch pedal bracket nutsclutch pedalclutch pedal rubberclutch pedal springOther Partsmanual brake pedalshifter assemblyshifter cables x2 one of each typeshifter cable clips x4 – Have some clips but not sure which ones, will post pictureshifter bootgear knobIf anyone has any of the parts that I still need then comment below with a price delivered please.Quick question about the clutch lines, is it only the 1 big solid metal line, a small soft rubber line and the slave cylinder with the short metal line attached that is on the car? Also how many clips/brackets are there as I may need some more? (currently 2 on big metal line and 1 on small metal line, 1 on soft line no bolts)Also a quick question about the clutch & brake pedal brackets. Does the clutch pedal just bolt up to the master cylinder or is there other bolts needed and also will the brake pedal bracket just bolt in with the bolts that are already there for the auto brake pedal?Picture of Clips
steve-gers Posted November 22, 2012 Author Posted November 22, 2012 bump require a clutch kit aswell now
rorenapier Posted November 22, 2012 Posted November 22, 2012 In the pic above, the 2 x bigger clips are for the shifter cables, the smaller on is for holding the soft line to the gear box mount.Solid line from the master cylinder, soft line, hard line, slave cylinder.Have a Exedy 3 puck paddle clutch here also.
steve-gers Posted November 22, 2012 Author Posted November 22, 2012 Spot on mate. What condition is the clutch in mate and how many miles has it covered? Thanks
rorenapier Posted November 22, 2012 Posted November 22, 2012 40,000 miles plus! Was put in when i rebuilt the motor.Still looks pretty damn good! Can send pics tomorow if you want.
steve-gers Posted November 22, 2012 Author Posted November 22, 2012 Yeah send me pics mate please. How much delivered?
steve-gers Posted November 23, 2012 Author Posted November 23, 2012 Clutch kit sorted. Other bolts still needed though. Does anyone at all have them? Even part numbers so I can buy them?
steve-gers Posted November 23, 2012 Author Posted November 23, 2012 Need a clutch fork now aswell so if anyone has one please post price delivered, thanks
Idrees Posted November 23, 2012 Posted November 23, 2012 Starter motor boltsClutch pressure plate boltsWe have these here, I've sent you a PM. CheersIdreesID-Workz
steve-gers Posted November 23, 2012 Author Posted November 23, 2012 Haven't got the PM yet could you re-send please. Thanks
steve-gers Posted November 23, 2012 Author Posted November 23, 2012 Anyone know if I will need a manual TPS?
steve-gers Posted November 24, 2012 Author Posted November 24, 2012 Still need the following parts if anyone has them:-manual gearbox bell housing boltsmanual starter motor boltsclutch pressure plate boltsshifter cable clips x2Also need to know if I need a manual TPS or if the auto one will do and also what holds the shifter cables onto the selector on the box?Idrees has hopefully got the starter motor and pressure plate bolts sorted for me just waiting to hear back from him.
steve-gers Posted November 27, 2012 Author Posted November 27, 2012 Still require the parts listed below if anyone has them, cash waiting, will pay for 1st class or next day delivery.- Manual gearbox bell housing bolts- Manual starter motor bolts- Clutch pressure plate bolts
Fealscott Posted November 27, 2012 Posted November 27, 2012 Two metal clips hold the selector cables onto the gearbox they just push on, and then pins attatch the ends to the selectors, dont think you need an auto tps, well i havent got one
steve-gers Posted November 27, 2012 Author Posted November 27, 2012 Cheers mate got r pins now just need the last 3 sets of bolts, may just have to order them from toyota as I need them ASAP.
daniel_g Posted November 27, 2012 Posted November 27, 2012 (edited) . Edited November 27, 2012 by daniel_g
steve-gers Posted November 27, 2012 Author Posted November 27, 2012 Not sure which size mate or how many but if you find out and have them then cash waiting. Forgot that I need the clutch protector plate/gasket bolts aswell so still need:-- Manual gearbox bell housing bolts- Manual starter motor bolts- Clutch pressure plate bolts- Clutch protector plate/gasket bolts
daniel_g Posted November 27, 2012 Posted November 27, 2012 Sorry mate cant guarantee i actually know where they are.But i'll have a dig for them and report back if i come across them.If not then give iddy a shout if you haven't already, will be cheaper than toyota.
steve-gers Posted November 27, 2012 Author Posted November 27, 2012 Yeah spoke to iddy, just waiting for him to get back to me.
steve-gers Posted November 28, 2012 Author Posted November 28, 2012 Can get these last bolts from gt bitz for £40 delivered, quite steep but really need them so buying them tomorrow unless anyone has got them cheaper.....
