I'm just about to do mine aswell so if you could take some pictures when you are doing it and some tips that would be great haha. There is a rough guide somewhere, I will find it for you.
Here it is
cheers, only thing i have noticed today is that when you remove the drive shafts the cups stay locked in the gearbox, is there any way of removing them ?
not sure if there just hard to get out or theres something locking them in, attacked it with a hammer but no joy!
il take heaps of pictures mayb make another guide
That would be really useful for me. Apparently cutting the hole in the bulk head is a nightmare? How much did you have to drop the engine down to get the box out, i.e did you have to disconnect any wires or pipes for slack?
The cups should still bang out of an auto box!!! im almost sure lukep used the auto shafts out of the auto box to put into his manual box too
Edited by micky boy
havent got the box out yet im still building my engine crane, going to take the engine completely out, makes it easier to cut the hole in the bulkhead and also i have pulleys to fit and uprated engine mounts so makes it easier. wont have time to do any more work on it till next weekend tho.
  • 2 weeks later...
any luck?
yes the cups came out with a hammer, also its a nightmare to get the clutch peddal in place and get the bolts on, cant even get a socket on the top bolt, theres no space lol
Did you take the engine out for the conversion? Maybe a universal joint would work on there or I have a set of ratchet spanners that should do the trick. Any problems with the conversion as I am hopefully doing mine next week.
yes took the engine out, couldnt get a drill in to drill holes in the bulkhead with it in. No real problems apart from getting the bolts done up on the clutch peddal, it sits right next to a black box kinda above it you cant get a spanner on it or a socket, going to have to take some of the dash off and remove the box i think, i will get pictures at the weekend its too dark when i get home through the week, also i am just using the auto rear gearbox mount as it looks the exact same as the manual one
Engine stays in use the auto shafts you need box, flywheel, clutch, linkages, slave and master cylinders, pedal, shifter. All plastics stay the same. Bridge the two big female terminals in the center of the big plug that was plugged into the auto box and you need to jam the slider on the under side of the ign barrel up or the key won't turn I just center punched mine till it jammed up.
Yeah rear mount is the same basically mate. Could you not have drilled the hole from the cabin as there is a cutout in the felt where the holes are? Not sure i like the sound of the bolting job, sounds a nightmare. I'm assuming that the ecu stays the same?
Easy did drilling on the inside as there's an indent as to where the master cylinder goes. Can't remember which bulb it was think it was the OD bulb.
Yeah I seen the indents but Fealscot reckons the bolts are a night mare to get on? OD bulb and selector lights can get electrical tape infront of them for now haha.
yeah cheers for the info, i am at the stage where i have the manual gearbox on the engine i am just putting my powerflex bushes into the mounts and then the engine will go back in, also need to get the clutch pedal bolts tight
you must have removed alot of dash bits to get a drill in then ? main reason i took the engine out is cause i had to fit powerflex mounts and change the pulleys + i drilled the holes from the other side
Hopefully but never seems to turn out that way. I can see the wee black box, it's close but should be out the way enough to mount the pedal, especially the bottom bolt it's miles out the road. Is the engine easy enough to take out?
