A L 3 X Posted November 3, 2012 Share Posted November 3, 2012 (edited) Are they? Just fitted some but thought I'd check before driving? Edited November 7, 2012 by A L 3 X Quote Link to post Share on other sites
starletburkie Posted November 4, 2012 Share Posted November 4, 2012 ya there are Quote Link to post Share on other sites
A L 3 X Posted November 4, 2012 Author Share Posted November 4, 2012 Nice one now I can drive without worrying lolCheers Quote Link to post Share on other sites
Ryan-11 Posted November 4, 2012 Share Posted November 4, 2012 Your still best to check them Quote Link to post Share on other sites
A L 3 X Posted November 4, 2012 Author Share Posted November 4, 2012 What should they be? Quote Link to post Share on other sites
starletburkie Posted November 4, 2012 Share Posted November 4, 2012 (edited) 1.1mm but they should be ok Edited November 4, 2012 by starletburkie Quote Link to post Share on other sites
Snow Posted November 4, 2012 Share Posted November 4, 2012 0.8 for a Glanza isn't it and 1.1 for a gt Quote Link to post Share on other sites
starletburkie Posted November 4, 2012 Share Posted November 4, 2012 0.8 for a Glanza isn't it and 1.1 for a gthows that mate? same engine.. Quote Link to post Share on other sites
Ryan-11 Posted November 4, 2012 Share Posted November 4, 2012 mines are gapped at .6 but i would of though .8 would b ok, 1.1 not too big? Quote Link to post Share on other sites
starletburkie Posted November 4, 2012 Share Posted November 4, 2012 maybe it is 0.8 i could be a bit wrong lol I've a new set on way must measure them Quote Link to post Share on other sites
A L 3 X Posted November 4, 2012 Author Share Posted November 4, 2012 I was gonna say, checked mine and they are deffo below 1.1mm Quote Link to post Share on other sites
steve-gers Posted November 4, 2012 Share Posted November 4, 2012 NGK bkr7eix iridium's have a factory gap of 0.8mm and bkr7eix-11 have a gap of 1.1mm. Quote Link to post Share on other sites
A L 3 X Posted November 4, 2012 Author Share Posted November 4, 2012 Ah, I think I got the first ones mate, is that ok? Quote Link to post Share on other sites
starletburkie Posted November 4, 2012 Share Posted November 4, 2012 there ok mate, same i use Quote Link to post Share on other sites
A L 3 X Posted November 4, 2012 Author Share Posted November 4, 2012 cool Quote Link to post Share on other sites
AdamB Posted November 5, 2012 Share Posted November 5, 2012 You want the largest gap possible without blowing out the spark. Quote Link to post Share on other sites
A L 3 X Posted November 5, 2012 Author Share Posted November 5, 2012 Should I be widening the gap then? What does that achieve? Quote Link to post Share on other sites
AdamB Posted November 6, 2012 Share Posted November 6, 2012 A wider gap gives a stronger spark, only if its not blowing out.I would start at 1.1mm, if you get a missfire under load, ie uphill 4th gear. Then gap it down to 1.00mm and so on. Quote Link to post Share on other sites
A L 3 X Posted November 6, 2012 Author Share Posted November 6, 2012 Ah I see mate, how come they aren't gapped like this from factory? Quote Link to post Share on other sites
Asad Posted November 6, 2012 Share Posted November 6, 2012 Factory spec = standard gap Modified = custom gap till the car is happy Quote Link to post Share on other sites
A L 3 X Posted November 6, 2012 Author Share Posted November 6, 2012 Ah right, well it seems to run ok now, but how do you know if it blows out the spark? Quote Link to post Share on other sites
Asad Posted November 6, 2012 Share Posted November 6, 2012 Cant remember the specifics but too much boost i think? Quote Link to post Share on other sites
steve-gers Posted November 6, 2012 Share Posted November 6, 2012 I will misfire, mostly higher up the rev range at full boost. Quote Link to post Share on other sites
Asad Posted November 6, 2012 Share Posted November 6, 2012 Hence people running bigger tubbys are wanting a coil pack setup which provides a stronger more stable spark especially at the upper rev limit Quote Link to post Share on other sites
A L 3 X Posted November 6, 2012 Author Share Posted November 6, 2012 Ah right so should I widen them to say 0.9 or 1mm to be safe? Quote Link to post Share on other sites
