daniel_g Posted November 4, 2012 Posted November 4, 2012 What are the differences between N/A and FTE rocker covers ?And can a 5E N/A rocker cover be modified into a 'race spec' cover with AN fittings etc. ?Cheers Quote
shorty Posted November 4, 2012 Posted November 4, 2012 Its missing an outlet on the na cover and the one outlet that is on em is in the wrong place iirc. I've a couple of spare 4e ones if your looking to buy one to be modded. Quote
daniel_g Posted November 4, 2012 Author Posted November 4, 2012 Thanks for the info man, there is a N/A one on the engine i'm getting so i would probably modify that into a 'race spec' one, i take it thats possible yeah ? And probably get an FTE cover in the mean time. Quote
AdamB Posted November 5, 2012 Posted November 5, 2012 You can mod the N/A one, but you will have to remove the baffle plate inside to drill through accurately. Quote
daniel_g Posted November 9, 2012 Author Posted November 9, 2012 Is removing that baffle plate easy to do ? Quote
PaulStarletSR Posted November 10, 2012 Posted November 10, 2012 just mark the hole then drill str8 thru cover and plate mate Quote
Rob H@RCH Engineering Posted November 10, 2012 Posted November 10, 2012 just mark the hole then drill str8 thru cover and plate mateThat would defeat the point of having a baffle plate, oil would get blown straight out the hole. I removed my baffle plate you have to grined off the lugs then drill and tap the holes and put bolts in with locktite that's what I did to make sure there's no bits left inside to fook up the engine, there's picks of mine in my build thread. Quote
